> Thanks for the info. I'm such a "der" sometimes! I do have another
> question. When I go to print a test page the cartridge slides and acts as
> if it is going to print and then locks up. I have tried several different
> things such as reinstall the driver, clean the print cartridges. It
seemed
> to be printing fine when Win '95 was on the workstation. Now suddenly it
> doesn't. Any ideas?
> Wendy Pursche
> Network Administrator
> Schmald Tool & Die, Inc.
> (810) 743-1600 ext.323
> wpursche@...
> From: Hiatt Manufacturing, Inc. <hiattmfg@...>
> To: <wpursche@...>
> Sent: Friday, November 10, 2000 3:02 PM
> Subject: RE: HP 500 Printer on NT
> > Wendy,
> > The HP 500 and 500c drivers come with NT. If you use the add printer
> wizard,
> > you can select HP as the printer brand, then scroll down to the 500 in
the
> > right hand pane that lists the printer models. This should work.
> > If you need further explanation, let me know. Good luck!
> > John Mueske
> > Hiatt Manufactuirng, Inc.
