Gen Ledger Entry Viewing
I have been looking at the fixed asset and when doing so I’ve been pulling out ledger entries by individual GL code using the Chart tracker.
I want to be able to look at all general ledger entries for all fixed asset codes and so I was wondering if there is a way within Epicor to do so.
Try General Ledger report.
To Identify which G/L’s are categorized as fixed assets go to…
Financial Management > General Ledger > Reports > Chart of Accounts Listing
Generate this report as a CSV so that way you can apply filters, then to go the Column labeled “Category”.
this should point you in the right direction to ensure you get all of the fixed asset G/L’s.
You can retrieve the details in the TB by filtering your defined COA category if you already have a classification for fixed assets. If not, create one and map it in the account segment values—just be sure your other reports align with the new grouping.
