Thank you very much Linda, that functions perfectly.
Appears I was on the right track in the first place, but the error I was getting kept me changing my code over and over. The error "Cannot find the row in the database" lingered (even with your code) until I shut down and restarted the client app and then all functioned.
Wonder if that's a known problem with BPM's or something.
Thanks again.
Thanks again.
--- In vantage@yahoogroups.com, "Linda Lowney" <llowney@...> wrote:
> I use the UD40 table to store a few keys, but some people use the
> Company table to store them. For UD02 I store the "next key" in the
> UD40.Number01 field, but you may want to store yours in the
> Company.Number01 field. Here is my code.
> /* Calculate UD02 Key1*/
> define variable vNextUD02Num as Integer.
> define variable vNextUD02Key as character.
> for each ttUD02 no-lock.
> /*Get the next UD02.Key1 number that is stored in
> UD40.Number01*/
> find UD40 where UD40.Company = cur-comp and UD40.Key1 = "1"
> no-lock.
> if UD40.Number01 = ? then do:
> vNextUD02Num = 1.
> end.
> if UD40.Number01 <> ? then do:
> vNextUD02Num = UD40.Number01.
> end.
> /*Store key number in the UD02 table */
> vNextUD02Key = string(VNextUD02Num).
> ttUD02.Key1 = vNextUD02Key.
> /*Update the next key in the UD40 table */
> vNextUD02Num = UD40.Number01 + 1.
> Run lib\UpdateTableBuffer.p(input BUFFER
> UD40:Handle,'Number01',vNextUD02Num).
> end.
> Of pbparker
> Sent: Monday, November 02, 2009 3:53 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Generate incrementing ID for custom table method?
> Anyone able to throw me a bone on this one.
> I started trying pre/post 4GL statements on both GetNewUD01 and
> GetANewUD01 and can't get the process of assigning a new row value via
> the code.
> I even tried to simplify it just to see if I could get the ttUD01.Key1
> value just set via 4GL with:
> assign ttUD01.Key1 = '17'.
> However, in all cases that statement results in:
> Cannot find the row in the database.
> My more elaborate attempts failed to do anything.
> DEFINE VARIABLE NextCounter as DECIMAL.
> FOR EACH UD02 no-lock.
> IF AVAILABLE UD02 THEN DO:
> ASSIGN NextCounter = UD02.Number01.
> ttUD01.Key1 = STRING(NextCounter).
> END.
> ELSE DO:
> ttUD01.Key1 = "NADA".
> END.
> END.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Linda Lowney" <llowney@> wrote:
> > Try UD01.GetANewUD01. I did not have any luck with the Get New without
> > the A in the middle.
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> > Of pbparker
> > Sent: Friday, October 30, 2009 5:00 PM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Generate incrementing ID for custom table method?
> > Can anyone share with me how they're generating a unique incrementing
> ID
> > for the key on custom forms/tables?
> > I'm using UD01 and have a form working just as I'd like, however I'd
> > like to generate an incrementing number.
> > I started trying to place a number in UD02.Number01 and tried to
> > reference and increment it from a UD01.GetNewUD01 BPM method but
> failed.
> > So, wondering if it needs to be in the form itself. Couldn't find a
> > AddRow event in the customization wizards so far.
