It actually already does this for Key5. Just use that as your ID.
On Fri, Dec 16, 2011 at 12:19 PM, cooner_55421 <cooner_55421@...>wrote:
> Hi John,
> Do you have Access to EpicWeb?
> AnswerBook #: 5867ESC might have the info you are looking for.
> Here is a link to the example:
> https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?/ePortal/ABDetail&rs:Command=Render&rc:Toolbar=true&Card_ID=5867ESC&Answerbook=Vantage%2fVista+8.0+-+General+Information+documents
> --- In vantage@yahoogroups.com, "lilj8069" <lilj8069@...> wrote:
> > We're creating an issue tracking tracker in 9.05.606 and I'd like the
> system to generate an ID # for the entries like it generates PO or Quote
> numbers. Is there a way to make this happen and have it generated into the
> Key1 Field of the UD01 table? I'm sure this is a rookie question but I
> haven't found anything in the documentation...
> > Thanks,
> > --John Kreger
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
