Get AppserverURL in EFx
Hey,
I have an Epicor function that I can fire from a classic customization or a REST call from a handheld device.
I need to grab the app server name to get access to an “out” folder to export a file to.
When I run the function from the classic customization I get the appserver name, but from the REST call I get the IP address.
The IP address version won’t let me create the file in my out folder.
Here’s the relevant code:
// build and export heat file
var context = (Erp.ErpContext)Ice.Services.ContextFactory.CreateContext();
var erpContext = new Erp.Internal.Lib.CCredChk(context); // used this library/assembly only for erpContext
// get server url
url = this.Session.AppServerURL;
Ring a bell?
Joe
Update: I tried getting the URL from an updatable query. I get the appserver name when I test in the BAQ designer, but the IP address when calling it from a function. Hmm.
Perhaps you can use what Epicor uses internally, one of the following:
It may be more reliable because the AppServerURL could be an IP Address.
Dns.GetHostEntry(Environment.MachineName).HostName
