getDefaults in HelpDesk
On the case entry screen, I want to create a new getDefaults event to always set the defaults to true to avoid the annoying pop up asking if you want to set the default to true.
Where can I hook this new event too and disable to old getDefaults for the case entry page?
Here is an example of how you can create your own event to replace the system one.
I made a copy of getDefaults. Set the Event/Override/getDefaults
It gives me an error. What I am trying to do is set the get defaults to true so it doesn’t open the slider.
