GetRows not filtering
Hi
I have spent ages looking at this and cant figure it out. Can anyone shed any light on why my code returns every row and is ignoring the where clause I have specified?
Thanks in advance.
Graeme
            adapt.BOConnect();
            Ice.Lib.Searches.SearchOptions so = new Ice.Lib.Searches.SearchOptions(Ice.Lib.Searches.SearchMode.AutoSearch);
            String whereClause = "Company = 'EPIC06' and plant = 'MfgSys'";
            so.DataSetMode = Ice.Lib.Searches.DataSetMode.RowsDataSet;
            so.NamedSearch.WhereClauses.Add("ShipViaCode", whereClause);
            System.Data.DataSet gs = adapt.GetRows(so,out more);
I am encountering the same issue with my code.
		Ice.Lib.Searches.SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
		//Ice.Lib.Searches.SearchOptions opts = new SearchOptions(SearchMode.ShowDialog);
        opts.DataSetMode = DataSetMode.RowsDataSet;
        // limit the number of rows
		opts.PageSize = 0;
		//string MyWhere = "SalesRepCode = '" + "CUSTSRV'" + " and " + "Key1 = '" + "164'";
		string MyWhere = string.Format("Key1 = \'164\'");
		opts.NamedSearch.WhereClauses.Add("TaskSeqs",MyWhere);
		System.Boolean morePages = false;
		// Call Adapter method (retuns a dataset dsTask):
		System.Data.DataSet dsTask = adapterTask.GetList(opts, out morePages);
		//You can also access the data in the dataset (trans in thiis case) like:
		// dsTask.Tables[0].Rows[0][1]
Key1 is a column in the Task table. I am using the adapterTask.
The first parameters in the where clause is the table name
-Jose
You can get a hint if you look in GetRows implementations in the appropriate BO (as opposed to the adapter)
base.AddTraceParam("whereClauseLaborHed", "System.String", "", whereClauseLaborHed);
		base.AddTraceParam("whereClauseLaborDtl", "System.String", "", whereClauseLaborDtl);
		base.AddTraceParam("whereClauseLaborDtlAttch", "System.String", "", whereClauseLaborDtlAttch);
		base.AddTraceParam("whereClauseLaborDtlComment", "System.String", "", whereClauseLaborDtlComment);
		base.AddTraceParam("whereClauseLaborEquip", "System.String", "", whereClauseLaborEquip);
		base.AddTraceParam("whereClauseLaborPart", "System.String", "", whereClauseLaborPart);
		base.AddTraceParam("whereClauseLbrScrapSerialNumbers", "System.String", "", whereClauseLbrScrapSerialNumbers);
		base.AddTraceParam("whereClauseLaborDtlGroup", "System.String", "", whereClauseLaborDtlGroup);
		base.AddTraceParam("whereClauseSelectedSerialNumbers", "System.String", "", whereClauseSelectedSerialNumbers);
		base.AddTraceParam("whereClauseSNFormat", "System.String", "", whereClauseSNFormat);
		base.AddTraceParam("whereClauseTimeWeeklyView", "System.String", "", whereClauseTimeWeeklyView);
		base.AddTraceParam("whereClauseTimeWorkHours", "System.String", "", whereClauseTimeWorkHours);
		base.AddTraceParam("pageSize", "System.Int32", "", pageSize);
		base.AddTraceParam("absolutePage", "System.Int32", "", absolutePage);
		base.AddTraceParam("morePages", "System.Boolean", "out", morePages);
Another tidbit to think about is the implementation on the server:
public UserFileTableset GetRows(
      string whereClauseUserFile,
      string whereClauseUserComp,
      string whereClauseUserCompExt,
      int pageSize,
      int absolutePage,
      out bool morePages)
            CurrentFullTableset = new UserFileTableset();
            Dictionary<IIceTable, string> tableWhereClauses = new Dictionary<IIceTable, string>();
            tableWhereClauses.Add(CurrentFullTableset.UserFile, whereClauseUserFile);
            tableWhereClauses.Add(CurrentFullTableset.UserComp, whereClauseUserComp);
            tableWhereClauses.Add(CurrentFullTableset.UserCompExt, whereClauseUserCompExt);
            InnerGetRows(Db, pageSize, absolutePage, out morePages, CurrentFullTableset, tableWhereClauses);
            return CurrentFullTableset;
The where clause parameters are placed into a dictionary so that the clause can be validated against the columns in the tables and prevent SQL Injection, cross company isolation, etc.
I find it odd that you did not receive some form of ‘malformed sql statement’ or the like. (I don’t remember the error text off the top of my head)
I did use a “try” block with show exception to catch any errors but nothing is being reported.
private void CallTaskAdapterGetRowsMethod(Int32 CurrentRow, Boolean ClearGrid)
try
	// Map Search Fields to Application Fields
	EpiDataView edvTask = ((EpiDataView)(this.oTrans.EpiDataViews["Task"]));
	// We have to override the current row because its being overwritten somehow.
	// When the list is changed the row will always be zero. So we pass it as a param.
	edvTask.Row = CurrentRow;
    System.Data.DataRow edvTaskRow = edvTask.CurrentDataRow; // This is left because it should return the current row which is set to 0
		String LKey1 = edvTaskRow["Key1"].ToString();
    	String LSalesRepCode = edvTaskRow["SalesRepCode"].ToString();
		TaskAdapter adapterTask = new TaskAdapter(this.oTrans);
		adapterTask.BOConnect();
		// Declare and Initialize Variables
		opts.PageSize = 0;
		string MyWhere = "(Key1 = '164')";
		DataSet dsTask = (DataSet) adapterTask.GetRows(opts, out morePages);
		// Place the dataset target table inside a dataview
		DataView dvTechBuyer = new DataView(dsTask.Tables[0]);
		//epiUltraGridC1.DataSource = dsTask.Tables[0];
		//MessageBox.Show("dvTechBuyer row count: " + dvTechBuyer.Count.ToString());
		// Sort the data view on TaskSeqNum in descending order
		dvTechBuyer.Sort = "TaskSeqNum DESC";
	// Populate the grid to view the results from the adapter where clause.
	   DataTable tblTechBuyers = dvTechBuyer.ToTable();
	   epiUltraGridC1.DataSource = tblTechBuyers;
		// Display the first row Name
		MessageBox.Show(dvTechBuyer[0]["Key1"] + " : "  + dvTechBuyer[0]["SalesRepCode"] + " : " + dvTechBuyer[0]["ChangeDcdUserID"]);
//adapterRow[“SalesRepCode”]
		// Cleanup Adapter Reference
		adapterTask.Dispose();
	} catch (System.Exception ex)
		ExceptionBox.Show(ex);
Is this information in available in 10.1.400 through object explorer in customization mode or do I have to search the BO reference schema? Maybe I am making this more complicated. I just need to search for rows in the Task table based on the value in Key1 and SalesRepCode columns.
As is the code returns all rows in the Task table. I am not sure if I understand you suggested code example. I was following previously posted code examples on the Internet. Also, I tried to add inner params through the business logic wizard for the adapterTask method GetRows but it would give an error each time. I am using 10.1.400.16.
I am not finding a reference for GetRows for the Task table in my BO reference schema:
Again, the first parameter in the whereClause is the Table name (Task) not Task Seq, also why are you escaping your single quotes in the whereClause?
Try this
TaskAdapter ta = new TaskAdapter(oTrans);
ta.BOConnect();
opts.PageSize = 0;
string MyWhere = string.Format("Key1 = '10001'");  //No need to escape the single quotes within a double quoted string
opts.NamedSearch.WhereClauses.Add("Task",MyWhere); //The first parameter is the Table name in the BO that will filter
var dsTask =(Erp.BO.TaskDataSet) ta.GetRows(opts, out morePages); //Use Get Rows not Get List if you want to get the entire dataset. Cast to TaskDataSet so you don't use a Generic Data set makes life easier
MessageBox.Show(dsTask.Task[0].RelatedToFile);
Fantabulous (Goooooooooal) it worked!!!
Mazin
Thank you both.
