I actually have another quick question that is related somewhat to getting the row. Right now I have it set up so that when you click on a row, it will look at the data in one column and use it to populate data in the same row of another column.
I would like for this copy of data to also take place for all the rows when you use the shift+click function between rows.
Would anyone happen to have some advice as to how I should go about this?
Thank you for your time!
--- In vantage@yahoogroups.com, "gkoutre" <gkoutre@...> wrote:
> Thank you that helped a lot!
> --- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@> wrote:
> > This should work to get you started...
> > Private Sub ugdEpiCustom1_AfterRowActivate(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles ugdEpiCustom1.AfterRowActivate
> > '// ** Place Event Handling Code Here **
> > Dim activeRow As UltraGridRow = ugdEpiCustom1.ActiveRow
> > Dim jobnumber as String = ugdEpiCustom1.ActiveRow.Cells(0).Value.ToString
> > Dim partnumber as String = ugdEpiCustom1.ActiveRow.Cells(1).Value.ToString
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gkoutre
> > Sent: Friday, May 24, 2013 8:10 AM
> > Subject: [Vantage] Getting the current row from an EpiUltraGrid
> > Hello,
> > I am currently working on an application where I need to get the current row selected in an EpiUltraGrid. How would I be able to pull this information?
> > Thank you for the time and help!
