We recently started experimenting with Global Scheduling and are trying to figure out if MRP should be run before or after Global Scheduling. We are of the belief that Global Scheduling should be run first so all the firm jobs are loaded to the resources and then any extra capacity if filled by MRP jobs.
Would love some insight on how other people run the process.
I believe that Global Scheduling run will give the same results as when doing MRP run, (our MRP per below screenshot) unless you need to use Adjust global scheduling order. If you need to do adjustment, I’d think to run MRP first then Global scheduling afterwards (after making adjust global scheduling order if needed).
Perhaps someone here can correct me if I’m wrong.
