Grab Custom Controls on forms
Problem is that the Chunk is BZiped and Hex Encoded…
poking around this will turn the “Chunk” data back into a string… You’ll need
NetSword.Common.ICSharpCode.SharpZipLib (nuget)
private string decompressString(string data)
    try
        int num;
        MemoryStream stream = new MemoryStream(Convert.FromBase64String(data));
        BZip2InputStream stream2 = new BZip2InputStream(stream);
        byte[] buffer = new byte[0x3e8];
        MemoryStream stream3 = new MemoryStream();
        while ((num = stream2.Read(buffer, 0, 0x3e8)) > 0)
            stream3.Write(buffer, 0, num);
        stream2.Close();
        stream.Close();
        byte[] bytes = stream3.ToArray();
        stream3.Close();
        return Encoding.UTF8.GetString(bytes);
    catch
        return data;
So if you want to do this you can BO GenXData
run GetRows where typecode=“Customization”
This will get you all the customizations in the system, then loop through all the XXXChunkRows and run the XXXChuck through that decompression aglorithm. Then use RegEx or another method to see if “CharacterXX, ShortCharXX, NumberXX, appear in the string”
It will turn this
 string myChunk= decompressString("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");
Into this
<CustomizationDS xmlns="http://tempuri.org/XMLSchema.xsd">
  <xs:schema id="CustomizationDS" targetNamespace="http://tempuri.org/XMLSchema.xsd" xmlns:mstns="http://tempuri.org/XMLSchema.xsd" xmlns="http://tempuri.org/XMLSchema.xsd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata" xmlns:msprop="urn:schemas-microsoft-com:xml-msprop" attributeFormDefault="qualified" elementFormDefault="qualified">
    <xs:element name="CustomizationDS" msdata:IsDataSet="true" msdata:Locale="" msprop:BuildVersion="9.05.702A">
      <xs:complexType>
        <xs:choice minOccurs="0" maxOccurs="unbounded">
          <xs:element name="Controls">
            <xs:complexType>
              <xs:sequence>
                <xs:element name="FormsID" type="xs:string" />
                <xs:element name="ControlName" type="xs:string" />
                <xs:element name="Key" type="xs:string" />
                <xs:element name="ParentControlKey" type="xs:string" />
                <xs:element name="ControlType" type="xs:string" />
                <xs:element name="Company" type="xs:string" />
                <xs:element name="Plant" type="xs:string" />
                <xs:element name="DcdUserId" type="xs:string" />
                <xs:element name="GroupID" type="xs:string" />
                <xs:element name="ControlsID" type="xs:string" />
              </xs:sequence>
            </xs:complexType>
          </xs:element>
          <xs:element name="Properties">
            <xs:complexType>
              <xs:sequence>
                <xs:element name="PropertyName" type="xs:string" />
                <xs:element name="PropertyValue" type="xs:string" />
                <xs:element name="DcdUserID" type="xs:string" />
                <xs:element name="PropertiesID" type="xs:string" />
              </xs:sequence>
            </xs:complexType>
          </xs:element>
        </xs:choice>
      </xs:complexType>
    </xs:element>
  </xs:schema>
  <Controls>
    <FormsID>BAQReportForm</FormsID>
    <ControlName>epicor.mfg.bo.transferorderentry.dll</ControlName>
    <Key>EpiString.ExecutionPath*epicor.mfg.bo.transferorderentry.dll</Key>
    <ParentControlKey />
    <ControlType>AssemblyReference</ControlType>
    <Company />
    <Plant />
    <DcdUserId />
    <GroupID />
    <ControlsID />
  </Controls>
  <Controls>
    <ControlName>epicor.mfg.if.itransferorderentry.dll</ControlName>
    <Key>EpiString.ExecutionPath*epicor.mfg.if.itransferorderentry.dll</Key>
    <Company />
    <Plant />
    <DcdUserId />
    <GroupID />
    <ControlsID />
  </Controls>
  <Controls>
    <ControlName>epicor.mfg.ad.transferorderentry.dll</ControlName>
    <Key>EpiString.ExecutionPath*epicor.mfg.ad.transferorderentry.dll</Key>
    <Company />
    <Plant />
    <DcdUserId />
    <GroupID />
    <ControlsID />
  </Controls>
  <Properties>
    <FormsID>filterListPanel1</FormsID>
    <ControlName>grdFilterList</ControlName>
    <Key>3c83f81e-470d-4ade-9646-152b68de99f2-1</Key>
    <PropertyName>ChildIndex</PropertyName>
    <PropertyValue>0</PropertyValue>
    <Company />
    <Plant />
    <DcdUserID />
    <GroupID />
    <PropertiesID />
  </Properties>
  <Properties>
    <ControlName>Customization</ControlName>
    <Key>2dcd1674-5e34-4d98-b493-c75747027376</Key>
    <PropertyName>Script</PropertyName>
    <PropertyValue>// **************************************************
// Custom code for BAQReportForm
// Created: 4/9/2015 1:45:56 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Epicor.Mfg.Core;
using Epicor.Mfg.UI;
using Epicor.Mfg.UI.Adapters;
using Epicor.Mfg.UI.Customization;
using Epicor.Mfg.UI.ExtendedProps;
using Epicor.Mfg.UI.FormFunctions;
using Epicor.Mfg.UI.FrameWork;
using Epicor.Mfg.UI.Searches;
public class Script
		// Begin Custom Code Disposal
		// End Custom Code Disposal
	private void BAQReportForm_Load(object sender, EventArgs args)
		string orderList = BAQReportForm.LaunchFormOptions.ValueIn.ToString();
		//data view for the order list
		EpiDataView orderListDV = (EpiDataView)(this.oTrans.EpiDataViews["FilterList1"]);
		//have to parse the orderList string to get the values
		if(!orderList.Contains("~")) {
			//add a row
			orderListDV.dataView.Table.Rows.Add();
			//set the default row value for the dataview
			orderListDV.Row = 0;
			//set the value order list value in the table if there's only one
			orderListDV.dataView.Table.Rows[0]["TFOrdNum"] = orderList;
		//if there are multiple order numbers in the order list
		else if(orderList.Contains("~")) {
			//put the order numbers into a string array
			string[] orderNums = orderList.Split('~');
			//loop through the string array and set each value on the grid
			for(int i = 0; i &lt; orderNums.Length; i++) {
				//add a row
				orderListDV.Row = i;
				//set the order number value
				orderListDV.dataView.Table.Rows[i]["TFOrdNum"] = orderNums[i];
</PropertyValue>
    <Company />
    <Plant />
    <DcdUserID />
    <GroupID />
    <PropertiesID />
  </Properties>
  <Properties>
    <PropertyName>Language</PropertyName>
    <PropertyValue>CSharp</PropertyValue>
    <Company />
    <Plant />
    <DcdUserID />
    <GroupID />
    <PropertiesID />
  </Properties>
</CustomizationDS>
