Grid Customization
I created a dropdown for the field in my grid. So you would create a dataset
with the values Pass and Fail. Then add that to your grid as a dropdown.
Dim grdSummaryOrderLines As EpiUltraGrid =
Ctype(csm.GetNativeControlReference("USE YOUR GRID EPIGUID"),EpiUltraGrid)
grdSummaryOrderLines.DisplayLayout.Bands(0).Columns("FIELDNAME").ValueList =
YOURDATASET
send me an email if this doesn't work and I'd be glad to help you.
Daniel
Karl Dash
Sent: Friday, January 23, 2009 2:35 PM
To: Vantage Group
Subject: [Vantage] Grid Customization
I have created a UD table that I am filling with data from the shop floor. A
couple of the entries need to be PASS or FAIL. I created a CombBox that will
limit the entries to those choices at the Detail level. Works OK.
The problem is that I want the info filled out in a grid. When I use the
grid layout, ANY value can be put in the fields instead of just PASS or
FAIL. How can I maintain the integrity of those fields in the grid layout?
TIA
-Karl
Â
I have created a UD table that I am filling with data from the shop floor. A couple of the entries need to be PASS or FAIL. I created a CombBox that will limit the entries to those choices at the Detail level. Works OK.
Â
The problem is that I want the info filled out in a grid. When I use the grid layout, ANY value can be put in the fields instead of just PASS or FAIL. How can I maintain the integrity of those fields in the grid layout?
Â
TIA
-Karl
