Perfect!
Thanks for the help.
--- On Tue, 12/9/08, bw2868bond <bwalker@...> wrote:
Subject: [Vantage] Re: Handling a RadioButton's click event
Date: Tuesday, December 9, 2008, 1:07 PM
How nice to know the click event doesn't fire....
Try using the CheckChanged event with an If statement to determine
the state...
Private Sub rdbEpiCustom1_ CheckedChanged( ByVal Sender As Object,
ByVal Args As System.EventArgs) Handles rdbEpiCustom1. CheckedChanged
'// ** Place Event Handling Code Here **
If (rdbEpiCustom1. Checked)
MessageBox.Show( "1 Checked")
End If
End Sub
--- In vantage@yahoogroups .com, Ahmet Erispaha <ahmeterispaha@ ...>
wrote:
> I want to show/hide a GroupBox by clicking one of two Radio
Buttons, but the Radio Button's Click event doesn't seem to fire.Â
What do I have to do?  Â
> Â
> I used the Event Wizard to create click event handlers for the two
Radio Buttons. Here's the code:
> Â
> '// Custom VB.NET code for UD05Form
> '// Created: 12/8/2008 2:58:13 PM
> Imports System
> Imports System.Data
> Imports System.Diagnostics
> Imports System.Windows. Forms
> Imports System.ComponentMod el
> Imports Microsoft.VisualBas ic
> Imports Epicor.Mfg.UI
> Imports Epicor.Mfg.UI. FrameWork
> Imports Epicor.Mfg.UI. ExtendedProps
> Imports Epicor.Mfg.UI. FormFunctions
> Imports Epicor.Mfg.UI. Customization
> Imports Epicor.Mfg.UI. Adapters
> Imports Epicor.Mfg.UI. Searches
> Imports Epicor.Mfg.BO
> Module Script
> Â '// ** Wizard Insert Location - Do Not Remove 'Begin/End Wizard
Added Module Level Variables' Comments! **
> Â '// Begin Wizard Added Module Level Variables **
> Â '// End Wizard Added Module Level Variables **
> Â '// Add Custom Module Level Variables Here **
> Â
> Â Sub InitializeCustomCod e()
> Â Â '// ** Wizard Insert Location - Do not delete 'Begin/End Wizard
Added Variable Intialization' lines **
> Â Â '// Begin Wizard Added Variable Intialization
> Â Â '// End Wizard Added Variable Intialization
> Â Â '// Begin Custom Method Calls
> Â Â '// End Custom Method Calls
> Â End Sub
> Â
> Â Sub DestroyCustomCode( )
Added Object Disposal' lines **
> Â Â '// Begin Wizard Added Object Disposal
> Â Â '// End Wizard Added Object Disposal
> Â Â '// Begin Custom Code Disposal
> Â Â '// End Custom Code Disposal
> Â End Sub
> Â
> Â Private Sub rdbEpiCustom1_ Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles rdbEpiCustom1. Click
> Â Â '// ** Place Event Handling Code Here **
> Â Â Â Â Â Â Â messagebox.show( "rdbEpiCustom1_ Click")
> Â Â Â Â grpEpiCustom1. Visible=True
> Â End Sub
> Â Private Sub rdbEpiCustom2_ Click(ByVal Sender As Object, ByVal Args
As System.EventArgs) Handles rdbEpiCustom2. Click
> Â Â Â Â Â Â Â grpEpiCustom1. Visible=False
> Â Â Â Â Â Â Â messagebox.show( "rdbEpiCustom2_ Click")
> Â End Sub
> End Module
> Â
> Thanks,
> Â
> Ahmet Erispaha
