Having to delete Customization on every change
I'm not sure of the version you are using, but in 8.03.4xx I think
you could use the "Purge Personalization" accessible from
Vantage\Utilities to simply delete all personalizations related to
the form you are working on. Still, if a user is currently working
with the form and has "Save on exit" activated it won't change a
thing.
--- In vantage@yahoogroups.com, "Michael McWilliams"
<mmcwilliams22@...> wrote:
> If a move a field or add one to the form, also if I add script, I
have
> to delete it from the client before the new version will load.
None
> of them are memory cached either.
> --- In vantage@yahoogroups.com, "Dave Thomas" <dthomas@> wrote:
> > What kind of customization are you talking about?
> > <mmcwilliams22@> wrote:
> > > It is getting rather annoying having to go to each computer,
> close
> > > Vantage and delete the version folder from Application data
every
> > time
> > > I make a small tweak to a customization. Anyone have any good
> > > solutions or a fix for this?
It is getting rather annoying having to go to each computer, close
Vantage and delete the version folder from Application data every time
time
If a move a field or add one to the form, also if I add script, I have
to delete it from the client before the new version will load. None
close
> time
close
> time
