Heat# Traceability
Thanks for the information - I know they are going to argue the point as we
make millions of parts - they just want to open a job and run.....
Have a great weekend!
Sent: Friday, April 04, 2003 5:18 PM
Subject: RE: [Vantage] Heat# Traceability
I will say from experience vantage will to a good job of lot tracking if you
match one heat of raw material to a single job. All you need is the job
number to tie everything out. We use document management here also to print
out the material certification sheet of the heat when we ship. Works well.
Patrick Winter
Sent: Friday, April 04, 2003 4:14 PM
To: 'vantage@yahoogroups.com'
That was met with resistance from our job scheduler and plant manager - that
may be what we end up doing - because we have to be able to tell a customer
what day, operator, etc. worked on a certain heat - if a problem were to
arise - end even further yet - what shipment was tied to that heat (which we
do currently with a vbform-and that info comes from the production card). I
just wanted to generate this all from Vantage. Thanks for your help.
Sent: Friday, April 04, 2003 5:08 PM
Any posibility of only issuing one heat to a job, such as sizing the job to
fit the heat or performing a lot split after the first heat is used up?
Patrick Winter
Sent: Friday, April 04, 2003 4:03 PM
I tried that - I can lot track the raw material, issue the material to the
job but, I need to know what production on that job is associated with that
material. We might have 2 lots of material at the machine. Currently the
operator writes the heat# on the pan ticket. I want to be able to print the
heat# from the material on my production tags. In other words I have
material off of my first operation - the operator fills out the ticket - 500
good pieces, date, operator, heat# from the material, next op, part number,
etc.
Sent: Friday, April 04, 2003 4:55 PM
This is what "LOT TRAKING" in the part file is for. If you check "LOT
TRACKING" you will be required to enter the "LOT NUMBER" which will be your
heat number when receiving, issuing, etc... Working with that material. Test
in your training database first don't just check off lot tracking on an
active part in your database. You will then have mixed inventory of non
tracked and lot tracked.
Patrick Winter
Sent: Friday, April 04, 2003 3:49 PM
Subject: [Vantage] Heat# Traceability
Does anyone have a good way of tracing heat numbers for material all the way
through the production cycle. We are ready to move to 5.1 and need to print
production labels - after the operator keys in their production counts - the
one piece of information we are required to have on these labels is the heat
number. I have the heat # on the material issued to the machine but, cannot
trace it to the actual production. I would like them to key it in - but,
alas a VBForm is not available. Any ideas ?
Thank you,
Kristine Pollard
American Turned Products
Fairview, PA
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/xaxhjB/hdqFAA/VygGAA/PhFolB/TM
Thank you,
Kristine Pollard
Fairview, PA
Patrick Winter
Thank you,
Kristine Pollard
Fairview, PA
etc.
Patrick Winter
Thank you,
Kristine Pollard
Fairview, PA
Patrick Winter
etc.
Patrick Winter
Thank you,
Kristine Pollard
Fairview, PA
Patrick Winter
etc.
Patrick Winter
Thank you,
Kristine Pollard
Fairview, PA
Patrick Winter
Patrick Winter
etc.
Patrick Winter
Thank you,
Kristine Pollard
Fairview, PA
