Help Joining 2 tables
Just taking another tack,
Can you build the query as a BAQ and take a look at the code that gets created. This might help you work out the correct syntax.
Cheers
Simon
--- In vantage@yahoogroups.com, Ephraim Feldman <effgroups@...> wrote:
> As a side point I think you have to join them on the partnum too. If not
> you will end up with a enormous number of records as each record will be
> multiplied by the number of records in the other table
> On 2013-06-05 2:31 PM, "Ephraim Feldman" <effgroups@...> wrote:
> > The no lock has to be placed after the whole statement and the format is
> > no-lock
> > On 2013-06-05 1:37 PM, "clederer@..." <clederer@...>
> > wrote:
> >> I'm trying to Join 2 tables ( Partplant & partbininfo) on a common field
> >> (company).
> >> In the query I'm also trying to have two other WHERE statements
> >> 1. partplant.plant = "Colorado"
> >> 2. partbininfo.BinNum = ""
> >> I've used SQL before, but am having a hard time with 4GL. This is the
> >> query I came up with, but it's reporting an error message:
> >> FOR EACH partbininfo no lock, each partplant no lock Where (partbininfo.
> >> company = partplant.Company)
> >> AND partplant.plant = "Colorado"
> >> and partbininfo.BinNum = ""
> >> ERROR MESSAGE: "Unable to understand after-- "no lock'. (247) PREPARE
> >> syntax is {FOR/PRESELECT} EACH OF.. WHERE.. etc". (7324)
I'm trying to Join 2 tables ( Partplant & partbininfo) on a common field (company).
I've used SQL before, but am having a hard time with 4GL. This is the query I came up with, but it's reporting an error message:
FOR EACH partbininfo no lock, each partplant no lock Where (partbininfo. company = partplant.Company)
ERROR MESSAGE: "Unable to understand after-- "no lock'. (247) PREPARE syntax is {FOR/PRESELECT} EACH OF.. WHERE.. etc". (7324)
Where are you trying to execute this query? From within what interface?
I'm assuming this isn't a BAQ question and that you may be using an external
query engine?
clederer@...
Sent: Wednesday, June 05, 2013 1:37 PM
Subject: [Vantage] Help Joining 2 tables
(company).
no-lock
> (company).
> no-lock
>> (company).
"no lock" should be "no-lock", the no-lock can go where it is located right after the table name.
Jim Kinneman
Encompass Solutions, Inc
> no-lock
> > (company).
