Help with BAM
Aaron, the manuals are rather weighty, thanks for your example code, it
works perfectly and taught me more than FOR EACH - END
John
Aaron Hoyt
Sent: Tuesday, 14 March 2006 12:23 AM
Subject: RE: [Vantage] Help with BAM
John,
I did the manuals routine. Found it to be to little benefit for the time.
Spent my time with Progress Help and it's examples. Some things (as with
the manual) won't apply because of the limits of the BAM, but it surprising
how far Help and some educated guesses can get you. :)
Good luck,
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of John Walter
Sent: Thursday, March 09, 2006 5:43 PM
Thanks Aaron, I will test this later today and let you know. I think its
time we (Hufcor) downloaded some Progress Manuals and got seriious about BAM
John
Hi all,
A challenge for the BAM experts out there. I have written a BAM .p program
to send an email to our Service Division people when an invoice is created
for our main products. It works fine when the invoice only has one line but
falls over if there is more than one line. I think the problem is my outer
join to the ShipTo table but nan't see a way around it. See code below, any
suggestions welcome
{ud/GlbAlert.i &TableName = "InvcHead"}
DEFINE VARIABLE Plant AS CHARACTER NO-UNDO.
DEFINE VARIABLE Project AS CHARACTER NO-UNDO.
FIND Mfgsys.InvcDtl Where (Mfgsys.InvcDtl.Company = Mfgsys.InvcHead.Company)
AND
(Mfgsys.InvcDtl.InvoiceNum = Mfgsys.InvcHead.InvoiceNum) NO-LOCK NO-ERROR.
IF NOT AVAILABLE Mfgsys.InvcDtl THEN DO:
RETURN "Cancel Send".
END.
FIND Mfgsys.Customer Where (Mfgsys.Customer.Company =
Mfgsys.InvcHead.Company) AND
(Mfgsys.Customer.CustNum = Mfgsys.InvcHead.CustNum) NO-LOCK NO-ERROR.
IF NOT AVAILABLE Mfgsys.Customer THEN DO:
END.
FIND Mfgsys.ShipTo OUTER-JOIN NO-LOCK Where (Mfgsys.ShipTo.Company =
Mfgsys.InvcDtl.Company) AND
(Mfgsys.ShipTo.CustNum = Mfgsys.InvcDtl.CustNum) AND
(Mfgsys.ShipTo.ShipToNum = Mfgsys.InvcDtl.ShipToNum) NO-ERROR.
IF NOT AVAILABLE Mfgsys.ShipTo THEN DO:
END.
Plant = Mfgsys.InvcHead.Plant.
Project = Mfgsys.InvcHead.InvoiceComment.
IF Mfgsys.InvcHead.Posted = No THEN DO:
RETURN "Cancel Send":U.
END.
IF Mfgsys.InvcHead.InvoiceType <> "Shp" THEN DO:
END.
IF Mfgsys.InvcHead.LineType = "Call" THEN DO:
END.
IF Mfgsys.InvcHead.Plant = "BBK" THEN DO:
END.
ELSE DO:
ASSIGN Email-Subject = "New Service Opportunity".
ASSIGN Email-Text = "Invoice No. " + string(InvcHead.InvoiceNum) + " has
just been raised for " + Project + ". Refer Sales Order " +
string(InvcDtl.OrderNum) + "~n~n"
+ "Customer is " + Customer.Name + "~n"
+ "Ship To Address1 - " + ShipTo.Address1 + "~n"
+ "Ship To Address2 - " + ShipTo.Address2 + "~n"
+ "Ship To Address3 - " + ShipTo.Address3 + "~n"
+ "City/State - " + ShipTo.City + " " + ShipTo.State.
CASE Plant:
WHEN "BBK" THEN
Email-To = "aaa@...".
WHEN "QLD" THEN
Email-To = "bbb@...".
WHEN "SA" THEN
Email-To = "ccc@...".
WHEN "GLASS" THEN
Email-To = david.l@....
WHEN "WA" THEN
Email-To = "ddd@...".
WHEN "NSW" THEN
Email-To = "eee@...".
WHEN "VSO" THEN
Email-To = "fff@...".
END CASE.
CASE Plant:
WHEN "QLD" THEN
Email-CC = "serviceqld@...".
WHEN "NSW" THEN
Email-CC = "servicensw@...".
END CASE.
END.
John Walter | National IS Advisor | Hufcor Pty Ltd
5-7 Trade Park Drive, Tullamarine, Victoria. 3250
Phone +613 9330 3733 | Fax +613 9338 9015
www.hufcor.com.au <http://www.hufcor.com.au/>
Hi,
Do your invoices contain multiple lines where some of the lines you
don't want to alert on? I am not too hot on this stuff but isn't
there a command like find first? You might not need the outer then
depending on the above.
As I say , I am not too good on this front.
--- In vantage@yahoogroups.com, "John Walter" <john.w@...> wrote:
> Hi all,
program
created
line but
my outer
below, any
> suggestions welcome
> AND
NO-ERROR.
> END.
ERROR.
> END.
> END.
> END.
> END.
> END.
> END.
> ELSE DO:
+ " has
> CASE Plant:
> WHEN "BBK" THEN
> WHEN "QLD" THEN
> WHEN "SA" THEN
> WHEN "GLASS" THEN
> WHEN "WA" THEN
> WHEN "NSW" THEN
> WHEN "VSO" THEN
> END CASE.
> CASE Plant:
> WHEN "QLD" THEN
> WHEN "NSW" THEN
> END CASE.
> END.
John,
In the first Find InvcDtl, wouldn't you want to set up a FOR EACH loop to
evaluate each of the detail lines?
I think I would do it with a numeric variable initialized to 0 and have it
add one for each detail line it finds and evaluates. Later, test the value
of the variable and if it's 0, cancel, if not, process the rest of the rules
for sending the email.
Just my thoughts, take it with a grain of salt.
Aaron Hoyt
Vantage Plastics
Of John Walter
Sent: Wednesday, March 08, 2006 6:57 PM
Subject: [Vantage] Help with BAM
Hi all,
suggestions welcome
AND
END.
END.
END.
END.
END.
END.
END.
ELSE DO:
CASE Plant:
WHEN "BBK" THEN
WHEN "QLD" THEN
WHEN "SA" THEN
WHEN "GLASS" THEN
WHEN "WA" THEN
WHEN "NSW" THEN
WHEN "VSO" THEN
END CASE.
CASE Plant:
WHEN "QLD" THEN
WHEN "NSW" THEN
END CASE.
END.
Yahoo! Groups Links
Thanks Aaron, do you have an example of the syntax for this, I am new to BAM
and what I have written below is my most complex BAM to date and involved
much blood, sweat and tears to get it to this point.
John
Aaron Hoyt
Sent: Friday, 10 March 2006 1:36 AM
John,
Aaron Hoyt
Vantage Plastics
Of John Walter
Hi all,
suggestions welcome
AND
END.
END.
END.
END.
END.
END.
END.
ELSE DO:
CASE Plant:
WHEN "BBK" THEN
WHEN "QLD" THEN
WHEN "SA" THEN
WHEN "GLASS" THEN
WHEN "WA" THEN
WHEN "NSW" THEN
WHEN "VSO" THEN
END CASE.
CASE Plant:
WHEN "QLD" THEN
WHEN "NSW" THEN
END CASE.
END.
Yahoo! Groups Links
Yahoo! Groups Links
No, I am looking to report on the basis that an invoice was created,
regardless of the number of lines so your suggestion might work
brychanwilliams
Sent: Thursday, 9 March 2006 7:43 PM
Subject: [Vantage] Re: Help with BAM
Hi,
Ok, I am sure I missed something, but...
Below is a direct modification of your code more the way I would approach.
This doesn't have my "style" to it because of the direct modification, but I
think the flow will work.
If nothing else it should give you an idea on using FOR EACH...END
statements.
Good luck
Aaron Hoyt
Vantage Plastics
DEFINE VARIABLE plant AS CHARACTER NO-UNDO.
DEFINE VARIABLE project AS CHARACTER NO-UNDO.
DEFINE VARIABLE ordr AS CHARACTER INITIAL "" NO-UNDO.
DEFINE VARIABLE num AS INTEGER INITIAL 0 NO-UNDO.
(Mfgsys.Customer.CustNum = Mfgsys.InvcHead.CustNum) NO-LOCK.
plant = Mfgsys.InvcHead.Plant.
project = Mfgsys.InvcHead.InvoiceComment.
FOR EACH Mfgsys.InvcDtl Where (Mfgsys.InvcDtl.Company =
AND
(Mfgsys.InvcDtl.InvoiceNum = Mfgsys.InvcHead.InvoiceNum) NO-LOCK.
num = num + 1.
FIND Mfgsys.ShipTo Where (Mfgsys.ShipTo.Company =
(Mfgsys.ShipTo.ShipToNum = Mfgsys.InvcDtl.ShipToNum) NO-LOCK.
IF ordr = ""
THEN DO:
ordr = ordr + string(InvcDtl.OrderNum).
END.
ELSE DO:
ordr = ordr + ", " + string(InvcDtl.OrderNum).
END.
END.
IF num = 0 THEN DO:
END.
END.
END.
END.
END.
ELSE DO:
just been raised for " + project + ". Refer Sales Order(s) " +
ordr + "~n~n"
CASE Plant:
WHEN "BBK" THEN
WHEN "QLD" THEN
WHEN "SA" THEN
WHEN "GLASS" THEN
WHEN "WA" THEN
WHEN "NSW" THEN
WHEN "VSO" THEN
END CASE.
END.
John
Aaron Hoyt
Sent: Friday, 10 March 2006 8:54 AM
statements.
Good luck
Aaron Hoyt
Vantage Plastics
AND
num = num + 1.
IF ordr = ""
THEN DO:
END.
ELSE DO:
END.
END.
IF num = 0 THEN DO:
END.
END.
END.
END.
END.
ELSE DO:
ordr + "~n~n"
CASE Plant:
WHEN "BBK" THEN
WHEN "QLD" THEN
WHEN "SA" THEN
WHEN "GLASS" THEN
WHEN "WA" THEN
WHEN "NSW" THEN
WHEN "VSO" THEN
END CASE.
END.
Yahoo! Groups Links
John,
Good luck,
Aaron Hoyt
Vantage Plastics
Of John Walter
John
Aaron Hoyt
statements.
Good luck
Aaron Hoyt
Vantage Plastics
AND
num = num + 1.
IF ordr = ""
THEN DO:
END.
ELSE DO:
END.
END.
IF num = 0 THEN DO:
END.
END.
END.
END.
END.
ELSE DO:
ordr + "~n~n"
CASE Plant:
WHEN "BBK" THEN
WHEN "QLD" THEN
WHEN "SA" THEN
WHEN "GLASS" THEN
WHEN "WA" THEN
WHEN "NSW" THEN
WHEN "VSO" THEN
END CASE.
END.
Yahoo! Groups Links
Yahoo! Groups Links
