I’m trying, from an SQL query, to get the open invoices. The goal is to get pretty much the same data from the Aged Receivables Report. I was wondering if there is a field somewhere that tells if the ar invoice is open or not?
InvcHead.OpenInvoice
It doesn’t seem to show the same data as the Aged Receivables Report if I just select the data WHERE InvcHead.OpenInvoice=1
Have you checked if InvcHead.Posted = 1?
Aged Receivables will show invoices already closed if the report date is before payments were made.
I used the Posted=1 and OpenInvoice=1 and I see the 5 invoices from the Aged Receivables Report. I’ll try to do other tests but it seems to work
I usually say InvcHead.InvoiceBal <> 0
