Thanks, that should help.
Mike
that_guyy
Sent: Monday, July 09, 2012 4:22 PM
Subject: [Vantage] Re: How do I add a field to a tracker list?
If you are on 9.04 or better you can use the "Field Help' option from the
Help menu to help determine the field's source:
1. First unhide one of the fields to the grid.
2. Then pull up a Supplier that will populate the gride with data.
3. Activate the Field Help sidebar from Help > Field Help
4. Switch the Field Help view to 'Technical Details'
5. Then Retreive some data in the grid and place your cursor in the field
you need to determine the DB source.
6. In the Field Help pane find the field that says 'DB Field:' this should
be the source DB Table.
-Rick Bird
IT Software Administrator
Rowmark, LLC.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Mike
Numbers" <mnumbers@...> wrote:
Behalf Of
Mike
that_guyy
-Rick Bird
Rowmark, LLC.
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Is there a way to identify which table the Date01-15 fields in the
> collection come from ?
> It appears both PODetail and PORel have Dates01-20.
> Mike
Behalf Of
> that_guyyEpicor
> Sent: Monday, July 09, 2012 2:56 PM
> Which PO date do you need?
> Most of the time this can be done with a personalization. By default
> Developers only show fields they think you need to see, however there areto
> other fields in the dataset but they are hidden. You can view these fields
> and unhide them by:
> 1. Open Supplier Tracker
> 2. Select 'Personalization' from the 'Tools' menu. The screen will change
> look similar to Customization Mode, but the toolbox will be different.The
> 3. Select the list form object from the program that you want to add to.
> toolbox options will change.label.
> 4. In the toolbox you will see a 'Layout' section with a 'Columns' setting
> that says 'Collection' next to it. This is a drop down of all the fields
> currently available for the list.
> 5. Hide/Unhide the fields you wish to add.
> 6. Select OK.
> For Safe Measure
> 7. Right click on the list view and select 'Save Layouts'
> 8. Select 'Save Layouts' from the Tools menu.
> This is per user.
> There are other options:
> 1. Create a new BAQ & Dashboard that has all the data that is needed and
> replace the tab via a customization with your dashboard.
> 2. Create a Data Directive or BPM to populate/update one of the Date UD
> fields that are available in the list view with the actual data from the
> real field. Then just set this UD field to be visible and change it's
> 3. Go into customization mode, select the list view. Then from thepost
> Customization Tools Dialog select Data Tools... from the Tools menu. Here
> you can create a new list or under 'Custom Column Like' you can define a
> foregin key relationship with another table and pull that field in. (It's
> been awhile since I did this, but the Epicor Tools User Guide should help
> you. I think there maybe a knownledgebase article on it, I will try to
> it if I can find it again.)<mailto:vantage%40yahoogroups.com> ,
> "mike.numbers" <mnumbers@> wrote:it
> > I have done some customizations to screens. I can add a field and bind
> to the database on a "standard" screen, but I have been asked to add thePO
> dates to the supplier tracker purchase order tab. This tab is a listversus
> the "standard" display. Looking with developer and customization, I cannot[Non-text portions of this message have been removed]
> see how I can add fields to the existing list. Can someone point me in the
> right direction on how to do this?
> > 9.04.507a
> > TIA
> > Mike
