Greetings:
As of today, 9.9.2025…our Planners can see a part in Time Phase out to June of next year. Does anyone know if that is able to be adjusted or does is Time Phase simply designed to show ~9 months ahead?
Greetings:
I thought it showed everything with no limit?
You should see all future document (SO, PO, etc.) activity. (I see one SO scheduled for 2030…I don’t know why its dated 2030…but its there in Time Phase.) But if your MRP is only set to look out 9 months ahead, then suggestions (PO sugg, unfirm jobs, etc.) will end at that 9 month point, as I understand it.
Also forecasts have their own limits (company config maybe).
More likely MRP or PO suggestion settings as was said already.
You could do a BAQ on PartDtl if you want to investigate.
Right but those are limits on things that are generating records that then show up in time phase. Time phase itself does not have a specific time limit.
I’d argue forecast is like that though.
Forecast records only show in Time Phase if within the +/- range in Company Config. But forecast records beyond that range still exist in PartDtl.
I know this from making BAQs off of PartDtl and trying to figure why my numbers didn’t match Time Phase.
That’s true, ran into that before.
