Just duplicating the part number field isn't enough, you'll have to make a new formula field.
You will have to make a string, concatenating asterisks on each end of the part number string.
Something like: "*" + {part.partnum} + "*"
Then place that field, change its font to the Dataworks one and you're good to go.
----- Original Message ----
Sent: Friday, September 5, 2008 3:21:39 PM
Subject: [Vantage] Re: How to add Barcodes to Crystal Report?
Alright. It worked out well. Is there any specific scripts we should
use on barcode field for scanning purposes? Or scanner will be able to
read it as it is?
Thank you very much
Erdal
--- In vantage@yahoogroups .com, "Dale Schuerman" <dale.schuerman@ ...>
read it as it is?
Thank you very much
Erdal
wrote:
>[Non-text portions of this message have been removed]
> Duplicate the part number field.
> Highlight the duplicated field and change the font to Dataworks Bar39
> and increase the font size(PrntTags. rpt uses 20).
> You will need to play with size for your paper and your barcode hardware
> functionality.
> Dale Schuerman
> Senior Consultant
> RAM Software Systems, Inc.
> 1701 North Collins Suite 200
> Richardson, Texas 75080
> Phone: (972) 669-0763
> Fax: (972) 669-9603
> Web Site: www.ramsys.com <blocked::http://www.ramsys com/>
> ____________ _________ _________ __
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
> Of empedole
> Sent: Friday, September 05, 2008 12:39 PM
> To: vantage@yahoogroups .com
> Subject: [Vantage] How to add Barcodes to Crystal Report?
> Hello all,
> Does anyone know how to add barcodes to Crystal Report? We have a
> report where we get information about our parts. What I want to do is
> printing Part Numbers and Barcodes at the same time.
> What is the proper way and possible conflicts that I should be aware of?
> Thank you
