In so far as I created a new quote, selected a pre-defined ShipTo that I knew had the necessary data, I believe so. Is there another way I can check what’s being exported?
Of course. Have amended to not use the AS statement just to see if it made a difference, but get the same result with or without.
Make sure you change the RDD the Report Style is using to your RDD that includes the shipto table.
We’re on Classic UI but Kinetic is similar:
All looks good there (we’re on classic as well, can’t get on with Kinetic!)
Then verify your RDD per @dcamlin’s post. Make sure the fields aren’t excluded and the relationship is setup per his images.
Sussed it in the end. Needed to change the relationship type to Output rather than Definition only.
Thanks for all the help all, massively appreciated.
Good to hear you got it figured out.
Ran into one of those today as well.
