How To: Adding Columns to Existing Kinetic Grid
There’s some speculation about whether we need to add some new widgets to the iteration event. @aosemwengie1 discovered that if you add the column, the view triggers the hasChanges property on the view to true and tries to call an update on the unchanged view and barks at ya.
To fix it, you need to add some widgets before and after the row-update widgets. (Bold is new)
event-row-disable > row-update > dataview-commit > event-row-enable
If you run into errors when going into the lines, review this post:
Adding a calculated field to a kinetic dataview? - Kinetic 202X - Epicor User Help Forum (epiusers.help)
