I am using epicor 9.05.702a, my epicor server and my sql server installed on SSD, with 1 Gbps on network. I tested the client using performance tools and give me good result. (no issue). But when epicor client loading and show the splash screen, it's took a age before the main menu is show up. can any one help me ?. how to boost the loading speed ?. the client using windows 7 with SSD and 8 GB memory and 1 Gbps network.
Can you access the Internet from that pc?
Check your proxy settings.
Some signed assemblies need to be verified online. Old. Net framework bug.
You have nothing to loose...
