I am trying to learn how jobs work having some trouble figuring out how to complete and close a job and have the job part move into stock in a warehouse.
I have made a job to produce a part, added some material and an operation to it. Move the material from stock to the job and added some labour time to the operation. When I try to complete/close the job I get a message that says the complete qty is less than the planned production qty. I get a similar message if I try to receipt from the job to inventory.
I seem to need to tell Epicor that we have made the parts but I don’t know how to do that?
Brett
You need to report quantity on the final operation to have a completed qty show in job tracker. Epicor defaults to the last operation, unless another is marked the final operation. Quantities can be done when an operation is completed or thru report quantity in mes.
Sent: Monday, January 11, 2016 8:56 PM
Subject: [Vantage] How to complete/close a job
Brett
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
also to complete/close a job......under Job Management (Gen Ops) select Job Closing - two separate tick boxes for each task. This essentially sets dates, the actual completion of subassemblies/operations depends on your MOM setup.
