How to display Part.Checkbox01 on Order/Quote Entry screen
Actually
I think I have sorted it. I am using multiple BPMs and using 'In Transaction'
instead.
Thanks for your help.
How am I able to populate InvcDtl.Checkbox01 with the Part.Checkbox01
information?
Sent: Wed, 20 July, 2011 8:23:50
Subject: Re: [Vantage] How to display Part.Checkbox01 on Order/Quote Entry
screen
Â
Hi Jose
That doesn't do anything.
I have followed your instructions below and when you add a part or save an
order, it does nothing.
Thanks.
Sent: Tue, 19 July, 2011 18:12:53
screen
ok data directives work just like BPM's but work on data changes
Go to Data Directives
Find the OrderDtl Table
Create a Standard Directive
with this action
FOR EACH ttOrderDtl :
FIND FIRST Part where Part.PartNum=ttOrderDtl.PartNum No-ERROR.
IF AVAILABLE PART THEN DO:
ASSIGN ttOrderDtl.CheckBox01 = Part.CheckBox01.
END.
END.
See if that works.
*Jose C Gomez*
Software Engineer
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
On Tue, Jul 19, 2011 at 12:33 PM, Chris Thompson <chriselectrix@...>wrote:
> We are on 9
> Never touched Data Directives before but they sound fun ;-)
> Once again thanks for the help so far and if you have the infor to set up a
> data
> directive it'd be appreciated.
> From: Jose Gomez <jose@...>
> Sent: Tue, 19 July, 2011 17:19:45
> screen
> What version are you on? 8 or 9? If you are on 9 we can replace the whole
> darn thing with a Data Directive.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
>Â <http://www.google.com/profiles/jose.gomez> <
>Â <http://www.josecgomez.com/professional-resume/>
>Â <http://www.usdoingstuff.com>
> On Tue, Jul 19, 2011 at 12:17 PM, Chris Thompson <chriselectrix@...
> >wrote:
> > I have tried the code you suggested on Quote > Create Order and Sales
> Order
> > Create Order From Quote but it didnt work.
> > This is the code you suggested (POST PROCESSING on Quote.CreateOrder:
> > FOR EACH OrderDtl where OrderDtl.OrderNum=orderNum:
> > FIND FIRST Part where Part.PartNum=OrderDtl.PartNum No-ERROR.
> > ASSIGN OrderDtl.CheckBox01 = Part.CheckBox01.
> > END.
> > END.
> > Do you know why it doesnt work?
> > Sent: Tue, 19 July, 2011 13:10:38
> Entry
> > screen
> > There is a method that you need to put a BPM on
> > Quote -> Create Order
> > SalesOrder -> Create Order From Quote
> > On SalesOrder upate the code should be on Pre-Processing
> > *Jose C Gomez*
> > Software Engineer
> > E: jose@...
> > On Tue, Jul 19, 2011 at 3:50 AM, Chris Thompson <chriselectrix@...
> > >wrote:
> > > Ok, I think i have found where it is going wrong but I have no idea how
> > to
> > > correct the problem.
> > > It only seems to not work when I re-load an order which has been
> created
> > by
> > > winning a quote.
> > > If I create a quote and add a part where Part.Checkbox01 = True,
> > > QuoteDtl.Checkbox01 = True which is correct and the part number field
> > > changes
> > > colour based on a row rule (where if QuoteDtl.Checkbox01= True
> then....).
> > > If I save the quote, close the screen, re-open the screen and re-open
> the
> > > quote,
> > > the tick box still remains.
> > > Likewise, if I create an order and add a part where Part.Checkbox01 =
> > True,
> > > then
> > > OrderDtl.Checkbox01 is populated with a tick, and the part number field
> > > changes
> > > colour based on my row rule.
> > > If I save the order, close the order entry screen, re-open the screen
> and
> > > re-load the order, the tick box will still be populated.
> > > HOWEVER - If I create a quote (with a part where Checkbox01 = True),
> then
> > > create
> > > an order in the quote screen by winning the task and choosing create
> > order,
> > > when
> > > I load the newly created order in the order entry screen, the tick box
> > for
> > > the
> > > part isn't populated (which is right - I know I need another BPM but I
> > > can't
> > > work out what I need to use and where I need to use it).
> > > If I then make a change to the newly created order and save the order,
> > the
> > > SalesOrder.Update is called (which is exactly the same code as below).
> > This
> > > acts
> > > as a double check so it checks the parts on the order -vs- the parts
> > where
> > > checkbox01 = true. If it finds a part on the order, it put a tick in
> the
> > > appropriate checkbox and changes the row colour accordingly.
> > > However, when you close the order entry screen and re-open it loading
> the
> > > order
> > > above, the OrderDtl.Checkbox01 that was populated is now empty (False)
> > and
> > > the
> > > row is not coloured. This is incorrect.
> > > From: Chris Thompson <chriselectrix@...>
> > > Sent: Tue, 19 July, 2011 8:08:56
> > Entry
> > > screen
> > > Yes I have another BPM/directive that was written by Epicor.
> > > There is nothing in there that I can see that would cause it to revert.
> > > It only works whilst you have that order loaded. As soon as you close
> the
> > > order
> > > screen and go back in, it goes.
> > > It's nothing to do with the temp tables is it?
> > > Sent: Mon, 18 July, 2011 15:46:31
> > Entry
> > > screen
> > > That doesn't make sense if it works once it works for ever, do you have
> a
> > > data directive or other BPM's on that method"?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > On Mon, Jul 18, 2011 at 8:45 AM, Chris Thompson <
> chriselectrix@...
> > > >wrote:
> > > > Actually I have this code - dont know where I got the other code from
> > > > FOR EACH ttOrderDtl:
> > > > FIND FIRST PART WHERE Part.PartNum = ttOrderDtl.PartNum
> > > > NO-ERROR.
> > > > IF AVAILABLE Part THEN DO:
> > > > Assign ttOrderDtl.Checkbox01=Part.Checkbox01.
> > > > END.
> > > > END.
> > > > So are you saying I should try this? ...
> > > > FIND FIRST PART WHERE Part.Company = ttOrderDtl.Company AND
> > Part.PartNum
> > > > ttOrderDtl.PartNum
> > > > NO-ERROR.
> > > > END.
> > > > END.
> > > > Why would it only work temporarily and then when you go back into the
> > > > screen/order the checkbox01 is no long populated?
> > > > From: Kevin Simon <simstrak@...>
> > > > Sent: Mon, 18 July, 2011 13:34:12
> > > > Subject: RE: [Vantage] How to display Part.Checkbox01 on Order/Quote
> > > Entry
> > > > screen
> > > > Chris,
> > > > You are not setting CheckBox01 in the code, you are only setting
> > > > Character01.
> > > > Also, you should always include the company on your FIND statements:
> > > > FIND FIRST PART WHERE Part.Company = ttOrderDtl.Company AND …
> > > > HTH,
> > > > Kevin Simon
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > Behalf
> > > > Of
> > > > Chris Thompson
> > > > Sent: Monday, July 18, 2011 5:56 AM
> > > > To: vantage@yahoogroups.com; jose@...
> > > Entry
> > > > screen
> > > > Hi Jose
> > > > I have noticed an issue with my BPM and hopefully you will be able to
> > > help.
> > > > Im using this code on SalesOrder.Update
> > > > NO-ERROR.
> > > > Assign ttOrderDtl.Character1=Part.Character01.
> > > > END.
> > > > END.
> > > > The purpose of this code it just to double check that Part.CheckBox01
> > is
> > > > assigned correctly to OrderDtl.Checkbox01 when the order is saved.
> > > > It works sometimes, however, when you close the order screen and go
> > back
> > > > into
> > > > it, the OrderDtl.Checkbox01 is set to false when it was previously
> set
> > to
> > > > true.
> > > > It doesnt seem to be saving the OrderDtl.Checkbox01 state. It only
> > seems
> > > to
> > > > be
> > > > temporarily holding this information whilst the screen is open.
> > > > Any suggestions would be greatly appreciated.
> > > > Thanks.
> > > > From: Jose Gomez <jose@... <mailto:jose%40josecgomez.com>
> > > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > > Sent: Thu, 30 June, 2011 14:26:29
> > > Entry
> > > > screen
> > > > In post processing you have the OrderNumber available as a data set
> so
> > > > using
> > > > similar code as before (this code must be run in post processing.
> > > > FOR EACH OrderDtl where OrderDtl.OrderNum=orderNum: (this orderNum
> > should
> > > > be
> > > > an available parameter)
> > > > END.
> > > > END.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@... <mailto:jose%40josecgomez.com>
> > > > <http://www.linkedin.com/in/josecgomez> <
> > > > On Thu, Jun 30, 2011 at 7:06 AM, Jose Gomez <jose@...
> > > > <mailto:jose%40josecgomez.com> > wrote:
> > > > > tt = temp table
> > > > > Sent from mobile
> > > > > On Jun 30, 2011 6:37 AM, "Chris Thompson" <chriselectrix@...
> > > > ><mailto:chriselectrix%40ymail.com> > wrote:
> > > > > > Hi
> > > > > > I am getting closer.
> > > > > > I now have it so if you are on Quote entry or Order Entry and
> type
> > in
> > > a
> > > > > part
> > > > > > that has Part.Checkbox01 = True, then it will in turn populate
> > > > > > QuoteDtl.Checkbox01 or OrderDtl.Checkbox01 to suit.
> > > > > > My difficulty now is if I change quote into an order (by ticking
> > > create
> > > > > order
> > > > > > from the task list).
> > > > > > I have found Quote.CreateOrder BO which is where I believe I
> should
> > > be
> > > > > doing the
> > > > > > code for this.
> > > > > > The code needs to somehow locate the new order that has been
> > created
> > > by
> > > > > ticking
> > > > > > create order then copy then populate the OrderDtl.Checkbox01 with
> > the
> > > > > > appropriate true/false.
> > > > > > This can either be done by pushing it from QuoteDtl.Checkbox01 or
> > the
> > > > > simpler
> > > > > > way (possibly) would be to check against Part.Checkbox01 again
> and
> > > > > populate the
> > > > > > checkbox that way.
> > > > > > How do I do this?
> > > > > > Also out of interest, what does tt mean before table names?
> > > > > > Sent: Wed, 29 June, 2011 17:11:34
> > Order/Quote
> > > > > Entry
> > > > > > screen
> > > > > > Depending on what data set you have available I am not sure look
> > and
> > > > see
> > > > > > what data sets you ahve available on that method. Shoyld be at
> the
> > > top
> > > > of
> > > > > > the code window.
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > On Wed, Jun 29, 2011 at 11:41 AM, Chris Thompson <
> > > > > chriselectrix@... <mailto:chriselectrix%40ymail.com> >wrote:
> > > > > >> Do you know if I would need to change anything to get it to work
> > for
> > > > > Quote
> > > > > >> Order?
> > > > > >> Sent: Wed, 29 June, 2011 16:16:41
> > Order/Quote
> > > > > Entry
> > > > > >> screen
> > > > > >> There is a method for turning Quote into an order hook on that
> the
> > > > same
> > > > > >> way.
> > > > > >> It should be fine with what you did. I forgot about that method.
> > > > > >> *Jose C Gomez*
> > > > > >> *Software Engineer*
> > > > > >> On Wed, Jun 29, 2011 at 11:13 AM, Chris Thompson <
> > > > > >> >wrote:
> > > > > >> > I have it working now. I am using it on
> > SalesOrder.ChangePartNum.
> > > > > >> > Will it be sufficient here or will it need to go elsewhere?
> > > > > >> > What happens if a quote is turned into an order?
> > > > > >> > Sent: Wed, 29 June, 2011 15:42:06
> > > Order/Quote
> > > > > >> Entry
> > > > > >> > screen
> > > > > >> > You may or may not have a ttOrderDtl available on post
> > processing
> > > > > GetNew
> > > > > >> so
> > > > > >> > try and run a few info messags as i suggested to make sure you
> > do
> > > > have
> > > > > it
> > > > > >> > Add
> > > > > >> > {lib\PublishInfoMsg.i &InfoMsg = "'TTORderLineNum ' +
> > > > > >> > STRING(ttOrderDtl.OrderLine) "}.
> > > > > >> > *Jose C Gomez*
> > > > > >> > *Software Engineer*
> > > > > >> > On Wed, Jun 29, 2011 at 10:39 AM, Jose Gomez <
> > jose@...
> > > > > >> wrote:
> > > > > >> > > Did it validate correctly? Are you getting an error? Try
> > adding
> > > a
> > > > > few
> > > > > >> > info
> > > > > >> > > messages in your code to make sure it is being called
> > > > > >> > > {lib\PublishInfoMsg.i &InfoMsg = "'MSG ' + Part.Character04
> > > > > >> > > *Jose C Gomez*
> > > > > >> > > *Software Engineer*
> > > > > >> > > On Wed, Jun 29, 2011 at 10:34 AM, Chris Thompson
> > > > > >> > ><chriselectrix@... <mailto:chriselectrix%40ymail.com>
> > > > >wrote:
> > > > > >> > >> I tried you suggestion ...
> > > > > >> > >> SalesOrder.GetNewOrderDtl Post-Processing
> > > > > >> > >> ... and it didnt work.
> > > > > >> > >> Sent: Wed, 29 June, 2011 15:31:26
> > > > > Order/Quote
> > > > > >> > Entry
> > > > > >> > >> screen
> > > > > >> > >> No offense man but that's not a very helpful reply.. What
> > > doesn't
> > > > > >> work?
> > > > > >> > >> *Jose C Gomez*
> > > > > >> > >> *Software Engineer*
> > > > > >> > >> On Wed, Jun 29, 2011 at 10:22 AM, Chris Thompson <
> > > > > >> > >> >wrote:
> > > > > >> > >> > That doesnt work
> > > > > >> > >> > Sent: Wed, 29 June, 2011 15:15:12
> > > > > Order/Quote
> > > > > >> > >> Entry
> > > > > >> > >> > screen
> > > > > >> > >> > Change the method in which it is, its right on on
> SO.Update
> > > try
> > > > > >> post
> > > > > >> > >> > processing on GetNewOrderDtl?
> > > > > >> > >> > *Jose C Gomez*
> > > > > >> > >> > *Software Engineer*
> > > > > >> > >> > On Wed, Jun 29, 2011 at 10:13 AM, Chris Thompson <
> > > > > >> > >> > >wrote:
> > > > > >> > >> > > Actually it is working but it is only displaying as the
> > > sales
> > > > > >> order
> > > > > >> > is
> > > > > >> > >> > > saved.
> > > > > >> > >> > > How can it work so it pulls it in as soon as the part
> and
> > > > > >> > description
> > > > > >> > >> are
> > > > > >> > >> > > loaded? rather than only loading after it is saved.
> > > > > >> > >> > > Sent: Wed, 29 June, 2011 15:02:01
> on
> > > > > >> Order/Quote
> > > > > >> > >> > Entry
> > > > > >> > >> > > screen
> > > > > >> > >> > > are you suing Character01? if so change to Checkbox1 on
> > the
> > > > > code.
> > > > > >> If
> > > > > >> > >> you
> > > > > >> > >> > > don't want them to modify it it needs to be made read
> > only
> > > > from
> > > > > >> > >> Extended
> > > > > >> > >> > > Properties
> > > > > >> > >> > > *Jose C Gomez*
> > > > > >> > >> > > *Software Engineer*
> > > > > >> > >> > > On Wed, Jun 29, 2011 at 10:00 AM, Chris Thompson <
> > > > > >> > >> > > >wrote:
> > > > > >> > >> > > > I think Im getting there but it isnt working yet.
> > > > > >> > >> > > > Im actually using Part.Checkbox01 on part maintenance
> > and
> > > > > >> > >> > > > OrderDtl.Checkbox01 on
> > > > > >> > >> > > > Order Entry.
> > > > > >> > >> > > > Im not getting any errors when I validate now
> (retyped
> > it
> > > > > rather
> > > > > >> > >> than
> > > > > >> > >> > > copy
> > > > > >> > >> > > > and
> > > > > >> > >> > > > paste as it didnt pick up on copy/paste correctly).
> > > > > >> > >> > > > Ive tested it, but it doesnt populate the tick box on
> > the
> > > > > sales
> > > > > >> > >> order
> > > > > >> > >> > > entry
> > > > > >> > >> > > > lines screen when i add a part that has a tick on
> part
> > > > > >> > maintenance.
> > > > > >> > >> > > > Also how can I get it so the tick box on order entry
> > > can't
> > > > be
> > > > > >> > >> modified?
> > > > > >> > >> > > > Sent: Wed, 29 June, 2011 14:56:13
> > on
> > > > > >> > Order/Quote
> > > > > >> > >> > > Entry
> > > > > >> > >> > > > screen
> > > > > >> > >> > > > LoL ok I wrote the syntax on here (email) so I didn't
> > > > > validate
> > > > > >> it
> > > > > >> > >> > needs
> > > > > >> > >> > > a
> > > > > >> > >> > > > peroid after the last end
> ttOrderDtl.PartNum
> > > > > >> NO-ERROR.
> > > > > >> > >> > > > END.
> > > > > >> > >> > > > END.
> > > > > >> > >> > > > And no you don't need to check anything and it should
> > be
> > > > > >> > Syncrnousl
> > > > > >> > >> > > > *Jose C Gomez*
> > > > > >> > >> > > > *Software Engineer*
> > > > > >> > >> > > > On Wed, Jun 29, 2011 at 9:48 AM, Chris Thompson <
> > > > > >> > >> > > > >wrote:
> > > > > >> > >> > > > > When I validate, I get this ...
> > > > > >> > >> > > > > The following application error was encountered:
> > > > > >> > >> > > > > ** Unable to understand after -- "END". (247)
> > > > > >> > D:\E9-TempFiles\13511518418486131471602482351942105938158158.p
> > > > > >> > >> > Could
> > > > > >> > >> > > > not
> > > > > >> > >> > > > > understand line 14. (198)
> > > > > >> > >> > > > > Also, do I need to select Call or Return?
> > > > > >> > >> > > > > Should it be synchronously or asynchronously ?
> > > > > >> > >> > > > > Should it be record nothing, record call, record
> call
> > > > > return,
> > > > > >> > >> record
> > > > > >> > >> > > > > return????
> > > > > >> > >> > > > > Thanks,
> > > > > >> > >> > > > > Sent: Wed, 29 June, 2011 14:33:48
> Part.Checkbox01
> > > on
> > > > > >> > >> Order/Quote
> > > > > >> > >> > > > Entry
> > > > > >> > >> > > > > screen
> > > > > >> > >> > > > > ALl of it goes under action - Run 4GL/ABL
> > > > > >> > >> > > > > *Jose C Gomez*
> > > > > >> > >> > > > > *Software Engineer*
> > > > > >> > >> > > > > On Wed, Jun 29, 2011 at 8:43 AM, Chris Thompson <
> > > > > >> > >> > > > > >wrote:
> > > > > >> > >> > > > > > Which part of this goes under the conditions
> > section
> > > > and
> > > > > >> which
> > > > > >> > >> part
> > > > > >> > >> > > > goes
> > > > > >> > >> > > > > > under
> > > > > >> > >> > > > > > the actions section?
> > > ttOrderDtl.PartNum
> > > > > >> > >> NO-ERROR.
> > > > > >> > >> > > > > > END.
> > > > > >> > >> > > > > > END
> > > > > >> > >> > > > > > Sent: Wed, 29 June, 2011 13:39:08
> > Part.Checkbox01
> > > > on
> > > > > >> > >> > Order/Quote
> > > > > >> > >> > > > > Entry
> > > > > >> > >> > > > > > screen
> > > > > >> > >> > > > > > It is method directive
> > > > > >> > >> > > > > > then select the Sales Oder BO
> > > > > >> > >> > > > > > and find a suitable method, you can do it before
> SO
> > > > > Update
> > > > > >> > >> create a
> > > > > >> > >> > > > > > pre-prosessiong directive as shown
> > > ttOrderDtl.PartNum
> > > > > >> > >> NO-ERROR.
> > > > > >> > >> > > > > > END.
> > > > > >> > >> > > > > > END
> > > > > >> > >> > > > > > That should do. it
> > > > > >> > >> > > > > > *Jose C Gomez*
> > > > > >> > >> > > > > > *Software Engineer*
> > > > > >> > >> > > > > > On Wed, Jun 29, 2011 at 8:34 AM, Chris Thompson <
> > > > > >> > >> > > > > > >wrote:
> > > > > >> > >> > > > > > > How do I create a BPM to do what you said?
> > > > > >> > >> > > > > > > Is it Method Directives? Then what?
> > > > > >> > >> > > > > > > What Method Code do I select etc?
> > > > > >> > >> > > > > > > Sent: Wed, 29 June, 2011 13:30:37
> > > Part.Checkbox01
> > > > > on
> > > > > >> > >> > > Order/Quote
> > > > > >> > >> > > > > > Entry
> > > > > >> > >> > > > > > > screen
> > > > > >> > >> > > > > > > BPM would be the best option, after GetNewDtl
> or
> > > > > something
> > > > > >> > >> like
> > > > > >> > >> > > that
> > > > > >> > >> > > > > you
> > > > > >> > >> > > > > > > can
> > > > > >> > >> > > > > > > copy the Part.Character01 to
> OrderDtl.Character01
> > > and
> > > > > that
> > > > > >> > >> would
> > > > > >> > >> > do
> > > > > >> > >> > > > it.
> > > > > >> > >> > > > > > > Another alternative would be a customization on
> > > > SoEntry
> > > > > >> > where
> > > > > >> > >> you
> > > > > >> > >> > > do
> > > > > >> > >> > > > a
> > > > > >> > >> > > > > > > lookup on part BO and then grab the value for
> > > > display.
> > > > > >> With
> > > > > >> > >> this
> > > > > >> > >> > > > > approach
> > > > > >> > >> > > > > > > however you would need to modify the RDD for
> > > SOEntry
> > > > to
> > > > > >> > >> Include a
> > > > > >> > >> > > > Link
> > > > > >> > >> > > > > to
> > > > > >> > >> > > > > > > the Part Table.
> > > > > >> > >> > > > > > > *Jose C Gomez*
> > > > > >> > >> > > > > > > *Software Engineer*
> > > > > >> > >> > > > > > > On Wed, Jun 29, 2011 at 7:51 AM, Chris Thompson
> > > > > >> > >> > > > > > > >wrote:
> > > > > >> > >> > > > > > > > Hi All
> > > > > >> > >> > > > > > > > I am starting to use Part.Checkbox01.
> > > > > >> > >> > > > > > > > How am I able to pull all of the information
> > > > through
> > > > > >> from
> > > > > >> > >> > > > > > Part.Checkbox01
> > > > > >> > >> > > > > > > > to the
> > > > > >> > >> > > > > > > > Order Detail and Quote Detail screens and
> > > > ultimately
> > > > > >> send
> > > > > >> > >> them
> > > > > >> > >> > in
> > > > > >> > >> > > > the
> > > > > >> > >> > > > > > XML
> > > > > >> > >> > > > > > > > on the
> > > > > >> > >> > > > > > > > quote and sales order ack print out so they
> can
> > > be
> > > > > >> > reported
> > > > > >> > >> on?
> > > > > >> > >> > > > > > > > Thanks.
> > > > > >> > >> > > > > > > > [Non-text portions of this message have been
> > > > removed]
> > > removed]
> > > > > >> > >> > > > > > > Useful links for the Yahoo!Groups Vantage Board
> > > are:
> > > > > >> Note:
> > > > > >> > >> You
> > > > > >> > >> > > > must
> > > > > >> > >> > > > > > have
> > > > > >> > >> > > > > > > already linked your email address to a yahoo id
> > to
> > > > > enable
> > > > > >> > >> access.
> > > > > >> > >> > > > > > > (1) To access the Files Section of our
> > Yahoo!Group
> > > > for
> > > > > >> > Report
> > > > > >> > >> > > Builder
> > > > > >> > >> > > > > and
> > > > > >> > >> > > > > > > Crystal Reports and other 'goodies', please
> goto:
> > > > > >> > >> > > > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > ><http://groups.yahoo.com/group/vantage/files/>
> > > > > >> > >> > > > > > > (2) To search through old msg's goto:
> > > > > >> > >> > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > >> > >> > > > > > > (3) To view links to Vendors that provide
> Vantage
> > > > > services
> > > > > >> > >> goto:
> http://groups.yahoo.com/group/vantage/linksYahoo
> > > > > Groups
> > > > > >> > >> Links
> > > removed]
> > removed]
> > are:
> > > > > Note:
> > > > > >> > >> You
> > > > > >> > >> > > must
> > > > > >> > >> > > > > have
> to
> > > > enable
> > > > > >> > >> access. )
> Yahoo!Group
> > > for
> > > > > >> Report
> > > > > >> > >> > Builder
> > > > > >> > >> > > > and
> > > > > >> > >> > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > >> > >> > > > > > (3) To view links to Vendors that provide Vantage
> > > > > services
> > > > > >> > goto:
> > > > Groups
> > > > > >> > Links
> > removed]
> removed]
> are:
> > > > > Note:
> > > > > >> > You
> > > > > >> > >> > must
> > > > > >> > >> > > > have
> > > > > >> > >> > > > > already linked your email address to a yahoo id to
> > > enable
> > > > > >> > access.
> > > > > >> > >> > > > > (1) To access the Files Section of our Yahoo!Group
> > for
> > > > > Report
> > > > > >> > >> Builder
> > > > > >> > >> > > and
> > > > services
> > > > > >&g
Hi All
How am I able to pull all of the information through from Part.Checkbox01 to the
Order Detail and Quote Detail screens and ultimately send them in the XML on the
quote and sales order ack print out so they can be reported on?
Thanks.
BPM would be the best option, after GetNewDtl or something like that you can
copy the Part.Character01 to OrderDtl.Character01 and that would do it.
Another alternative would be a customization on SoEntry where you do a
lookup on part BO and then grab the value for display. With this approach
however you would need to modify the RDD for SOEntry to Include a Link to
the Part Table.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Jun 29, 2011 at 7:51 AM, Chris Thompson <chriselectrix@...>wrote:
> Hi All
> to the
> on the
> Thanks.
screen
the Part Table.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi All
> to the
> on the
> Thanks.
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
http://groups.yahoo.com/group/vantage/files/.%c2%a0
and find a suitable method, you can do it before SO Update create a
FIND FIRST PART WHERE Part.PartNum = ttOrderDtl.PartNum NO-ERROR.
END.
END
That should do. it
*Jose C Gomez*
*Software Engineer*
E: jose@...
> screen
> can
> the Part Table.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> >wrote:
> > Hi All
> > to the
> > on the
> > Thanks.
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
Which part of this goes under the conditions section and which part goes under
END.
END
screen
END.
END
That should do. it
*Jose C Gomez*
*Software Engineer*
E: jose@...
> screen
> can
> the Part Table.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> >wrote:
> > Hi All
> > to the
> > on the
> > Thanks.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> under
> END.
> END
> screen
> END.
> END
> That should do. it
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Entry
> > screen
> > can
> > the Part Table.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > >wrote:
> > > Hi All
> Part.Checkbox01
> > > to the
> XML
> > > on the
> > > Thanks.
> have
** D:\E9-TempFiles\13511518418486131471602482351942105938158158.p Could not
Â
Â
Should it be record nothing, record call, record call return, record return????
screen
*Jose C Gomez*
*Software Engineer*
E: jose@...
> under
> END.
> END
> screen
> END.
> END
> That should do. it
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> Entry
> > screen
> > can
> > the Part Table.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > >wrote:
> > > Hi All
> Part.Checkbox01
> > > to the
> XML
> > > on the
> > > Thanks.
> have
LoL ok I wrote the syntax on here (email) so I didn't validate it needs a
END.
END.
And no you don't need to check anything and it should be Syncrnousl
*Jose C Gomez*
*Software Engineer*
E: jose@...
> return????
> Thanks,
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > under
> > END.
> > END
> Entry
> > screen
> > END.
> > END
> > That should do. it
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > Entry
> > > screen
> you
> > > can
> approach
> to
> > > the Part Table.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > > >wrote:
> > > > Hi All
> > Part.Checkbox01
> > > > to the
> > XML
> > > > on the
> > > > Thanks.
> > have
> and
> have
Im actually using Part.Checkbox01 on part maintenance and OrderDtl.Checkbox01 on
Order Entry.
Im not getting any errors when I validate now (retyped it rather than copy and
Ive tested it, but it doesnt populate the tick box on the sales order entry
lines screen when i add a part that has a tick on part maintenance.
Also how can I get it so the tick box on order entry can't be modified?
screen
END.
END.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> return????
> Thanks,
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > under
> > END.
> > END
> Entry
> > screen
> > END.
> > END
> > That should do. it
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > Entry
> > > screen
> you
> > > can
> approach
> to
> > > the Part Table.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > > >wrote:
> > > > Hi All
> > Part.Checkbox01
> > > > to the
> > XML
> > > > on the
> > > > Thanks.
> > have
> and
> have
are you suing Character01? if so change to Checkbox1 on the code. If you
don't want them to modify it it needs to be made read only from Extended
Properties
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Order Entry.
> and
> screen
> END.
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> not
> > return????
> > Thanks,
> Entry
> > screen
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> goes
> > > under
> > > END.
> > > END
> > Entry
> > > screen
> > > END.
> > > END
> > > That should do. it
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > > Entry
> > > > screen
> > you
> > > > can
> it.
> a
> > approach
> Link
> > to
> > > > the Part Table.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > > > >wrote:
> > > > > Hi All
> > > Part.Checkbox01
> > > > > to the
> the
> > > XML
> > > > > on the
> > > > > Thanks.
> must
> > > have
> > and
> > have
> and
> have
Im using Checkbox01 on both.
On the sales order entry screen, I have added OrderDtl.Checkbox01. Should it be
ttOrderDtl?
I have set it up as SalesOrder.Update Pre-Processing.
What am I doing wrong?
screen
Properties
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Order Entry.
> and
> screen
> END.
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> not
> > return????
> > Thanks,
> Entry
> > screen
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> goes
> > > under
> > > END.
> > > END
> > Entry
> > > screen
> > > END.
> > > END
> > > That should do. it
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > > Entry
> > > > screen
> > you
> > > > can
> it.
> a
> > approach
> Link
> > to
> > > > the Part Table.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > > > >wrote:
> > > > > Hi All
> > > Part.Checkbox01
> > > > > to the
> the
> > > XML
> > > > > on the
> > > > > Thanks.
> must
> > > have
> > and
> > have
> and
> have
Actually it is working but it is only displaying as the sales order is saved.
How can it work so it pulls it in as soon as the part and description are
screen
Properties
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Order Entry.
> and
> screen
> END.
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> not
> > return????
> > Thanks,
> Entry
> > screen
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> goes
> > > under
> > > END.
> > > END
> > Entry
> > > screen
> > > END.
> > > END
> > > That should do. it
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > > Entry
> > > > screen
> > you
> > > > can
> it.
> a
> > approach
> Link
> > to
> > > > the Part Table.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > > > >wrote:
> > > > > Hi All
> > > Part.Checkbox01
> > > > > to the
> the
> > > XML
> > > > > on the
> > > > > Thanks.
> must
> > > have
> > and
> > have
> and
> have
Change the method in which it is, its right on on SO.Update try post
*Jose C Gomez*
*Software Engineer*
E: jose@...
> saved.
> screen
> Properties
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Order Entry.
> copy
> > and
> entry
> Entry
> > screen
> a
> > END.
> > END.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > not
> > > return????
> > > Thanks,
> > Entry
> > > screen
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > goes
> > > > under
> > > > END.
> > > > END
> > > Entry
> > > > screen
> > > > END.
> > > > END
> > > > That should do. it
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> Order/Quote
> > > > Entry
> > > > > screen
> that
> > > you
> > > > > can
> > it.
> do
> > a
> > > approach
> > Link
> > > to
> > > > > the Part Table.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> > > > > >wrote:
> > > > > > Hi All
> > > > Part.Checkbox01
> > > > > > to the
> > the
> > > > XML
> > > > > > on the
> > > > > > Thanks.
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
That doesnt work
screen
*Jose C Gomez*
*Software Engineer*
E: jose@...
> saved.
> screen
> Properties
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Order Entry.
> copy
> > and
> entry
> Entry
> > screen
> a
> > END.
> > END.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > not
> > > return????
> > > Thanks,
> > Entry
> > > screen
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> > goes
> > > > under
> > > > END.
> > > > END
> > > Entry
> > > > screen
> > > > END.
> > > > END
> > > > That should do. it
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> Order/Quote
> > > > Entry
> > > > > screen
> that
> > > you
> > > > > can
> > it.
> do
> > a
> > > approach
> > Link
> > > to
> > > > > the Part Table.
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> > > > > >wrote:
> > > > > > Hi All
> > > > Part.Checkbox01
> > > > > > to the
> > the
> > > > XML
> > > > > > on the
> > > > > > Thanks.
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
No offense man but that's not a very helpful reply.. What doesn't work?
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Jun 29, 2011 at 10:22 AM, Chris Thompson <chriselectrix@...>wrote:
> That doesnt work
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > saved.
> Entry
> > screen
> > Properties
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> chriselectrix@...
> > > Order Entry.
> > copy
> > > and
> > entry
> > Entry
> > > screen
> needs
> > a
> > > END.
> > > END.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> Could
> > > not
> > > > return????
> > > > Thanks,
> > > Entry
> > > > screen
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > > goes
> > > > > under
> > > > > END.
> > > > > END
> Order/Quote
> > > > Entry
> > > > > screen
> > > > > END.
> > > > > END
> > > > > That should do. it
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> > Order/Quote
> > > > > Entry
> > > > > > screen
> > that
> > > > you
> > > > > > can
> do
> > > it.
> > do
> > > a
> > > > approach
> > > Link
> > > > to
> > > > > > the Part Table.
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > > chriselectrix@...
> > > > > > >wrote:
> > > > > > > Hi All
> > > > > Part.Checkbox01
> > > > > > > to the
> in
> > > the
> > > > > XML
> > > > > > > on the
> > > > > > > Thanks.
> > > must
> > > > > have
> > Builder
> > > > and
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
screen
*Jose C Gomez*
*Software Engineer*
E: jose@...
> That doesnt work
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > saved.
> Entry
> > screen
> > Properties
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> chriselectrix@...
> > > Order Entry.
> > copy
> > > and
> > entry
> > Entry
> > > screen
> needs
> > a
> > > END.
> > > END.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> chriselectrix@...
> Could
> > > not
> > > > return????
> > > > Thanks,
> > > Entry
> > > > screen
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > > goes
> > > > > under
> > > > > END.
> > > > > END
> Order/Quote
> > > > Entry
> > > > > screen
> > > > > END.
> > > > > END
> > > > > That should do. it
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> > Order/Quote
> > > > > Entry
> > > > > > screen
> > that
> > > > you
> > > > > > can
> do
> > > it.
> > do
> > > a
> > > > approach
> > > Link
> > > > to
> > > > > > the Part Table.
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > > chriselectrix@...
> > > > > > >wrote:
> > > > > > > Hi All
> > > > > Part.Checkbox01
> > > > > > > to the
> in
> > > the
> > > > > XML
> > > > > > > on the
> > > > > > > Thanks.
> > > must
> > > > > have
> > Builder
> > > > and
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
Did it validate correctly? Are you getting an error? Try adding a few info
{lib\PublishInfoMsg.i &InfoMsg = "'MSG ' + Part.Character04 "}.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> >wrote:
> > That doesnt work
> Entry
> > screen
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> chriselectrix@...
> > > saved.
> are
> > Entry
> > > screen
> you
> Extended
> > > Properties
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > chriselectrix@...
> > > > Order Entry.
> > > copy
> > > > and
> > > entry
> modified?
> > > Entry
> > > > screen
> > needs
> > > a
> > > > END.
> > > > END.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > Could
> > > > not
> record
> > > > > return????
> > > > > Thanks,
> Order/Quote
> > > > Entry
> > > > > screen
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> part
> > > > goes
> > > > > > under
> > > > > > END.
> > > > > > END
> > Order/Quote
> > > > > Entry
> > > > > > screen
> a
> > > > > > END.
> > > > > > END
> > > > > > That should do. it
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > > chriselectrix@...
> > > Order/Quote
> > > > > > Entry
> > > > > > > screen
> > > that
> > > > > you
> > > > > > > can
> would
> > do
> > > > it.
> you
> > > do
> > > > a
> this
> > > > > approach
> a
> > > > Link
> > > > > to
> > > > > > > the Part Table.
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@...
> > > > > chriselectrix@...
> > > > > > > >wrote:
> > > > > > > > Hi All
> > > > > > Part.Checkbox01
> > > > > > > > to the
> them
> > in
> > > > the
> > > > > > XML
> > > > > > > > on the
> on?
> > > > > > > > Thanks.
> You
> > > > must
> > > > > > have
> access.
> > > Builder
> > > > > and
> goto:
> > > must
> > > > > have
> > Builder
> > > > and
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
You may or may not have a ttOrderDtl available on post processing GetNew so
try and run a few info messags as i suggested to make sure you do have it
Add
*Jose C Gomez*
*Software Engineer*
E: jose@...
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> <http://www.josecgomez.com/professional-resume/> <http://www.josecgomez.com/feed/>
>> screen
>> *Jose C Gomez*
>> *Software Engineer*
>> E: jose@...
>> >wrote:
>> > That doesnt work
>> Entry
>> > screen
>> > *Jose C Gomez*
>> > *Software Engineer*
>> > E: jose@...
>> chriselectrix@...
>> > > saved.
>> are
>> > Entry
>> > > screen
>> you
>> Extended
>> > > Properties
>> > > *Jose C Gomez*
>> > > *Software Engineer*
>> > > E: jose@...
>> > chriselectrix@...
>> > > > Order Entry.
>> than
>> > > copy
>> > > > and
>> order
>> > > entry
>> modified?
>> > > Entry
>> > > > screen
>> > needs
>> > > a
>> > > > END.
>> > > > END.
>> > > > *Jose C Gomez*
>> > > > *Software Engineer*
>> > > > E: jose@...
>> > chriselectrix@...
>> > Could
>> > > > not
>> record
>> > > > > return????
>> > > > > Thanks,
>> Order/Quote
>> > > > Entry
>> > > > > screen
>> > > > > *Jose C Gomez*
>> > > > > *Software Engineer*
>> > > > > E: jose@...
>> > > chriselectrix@...
>> part
>> > > > goes
>> > > > > > under
>> NO-ERROR.
>> > > > > > END.
>> > > > > > END
>> > Order/Quote
>> > > > > Entry
>> > > > > > screen
>> create a
>> NO-ERROR.
>> > > > > > END.
>> > > > > > END
>> > > > > > That should do. it
>> > > > > > *Jose C Gomez*
>> > > > > > *Software Engineer*
>> > > > > > E: jose@...
>> > > > chriselectrix@...
>> > > Order/Quote
>> > > > > > Entry
>> > > > > > > screen
>> like
>> > > that
>> > > > > you
>> > > > > > > can
>> would
>> > do
>> > > > it.
>> you
>> > > do
>> > > > a
>> this
>> > > > > approach
>> Include a
>> > > > Link
>> > > > > to
>> > > > > > > the Part Table.
>> > > > > > > *Jose C Gomez*
>> > > > > > > *Software Engineer*
>> > > > > > > E: jose@...
>> > > > > chriselectrix@...
>> > > > > > > >wrote:
>> > > > > > > > Hi All
>> > > > > > Part.Checkbox01
>> > > > > > > > to the
>> them
>> > in
>> > > > the
>> > > > > > XML
>> > > > > > > > on the
>> on?
>> > > > > > > > Thanks.
>> You
>> > > > must
>> > > > > > have
>> access.
>> > > Builder
>> > > > > and
>> goto:
>> Links
>> You
>> > > must
>> > > > > have
>> access. )
>> > Builder
>> > > > and
>> > must
>> > > > have
>> Builder
>> > > and
>> must
>> > > have
>> Builder
>> > and
>> > have
>> and
>> have
>> and
>> have
Ive tried putting a message in, but it calls as soon as you click on new line.
I need it to be called as soon as the part details load in.
Any ideas?
Sent: Wed, 29 June, 2011 15:39:40
screen
*Jose C Gomez*
*Software Engineer*
E: jose@...
> screen
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> >wrote:
> > That doesnt work
> Entry
> > screen
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> chriselectrix@...
> > > saved.
> are
> > Entry
> > > screen
> you
> Extended
> > > Properties
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > chriselectrix@...
> > > > Order Entry.
> > > copy
> > > > and
> > > entry
> modified?
> > > Entry
> > > > screen
> > needs
> > > a
> > > > END.
> > > > END.
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > chriselectrix@...
> > Could
> > > > not
> record
> > > > > return????
> > > > > Thanks,
> Order/Quote
> > > > Entry
> > > > > screen
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > chriselectrix@...
> part
> > > > goes
> > > > > > under
> > > > > > END.
> > > > > > END
> > Order/Quote
> > > > > Entry
> > > > > > screen
> a
> > > > > > END.
> > > > > > END
> > > > > > That should do. it
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > > chriselectrix@...
> > > Order/Quote
> > > > > > Entry
> > > > > > > screen
> > > that
> > > > > you
> > > > > > > can
> would
> > do
> > > > it.
> you
> > > do
> > > > a
> this
> > > > > approach
> a
> > > > Link
> > > > > to
> > > > > > > the Part Table.
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@...
> > > > > chriselectrix@...
> > > > > > > >wrote:
> > > > > > > > Hi All
> > > > > > Part.Checkbox01
> > > > > > > > to the
> them
> > in
> > > > the
> > > > > > XML
> > > > > > > > on the
> on?
> > > > > > > > Thanks.
> You
> > > > must
> > > > > > have
> access.
> > > Builder
> > > > > and
> goto:
> > > must
> > > > > have
> > Builder
> > > > and
> > must
> > > > have
> Builder
> > > and
> must
> > > have
> > and
> > have
> and
> have
