I have no BPM set up for POdetail.
But I do have EpiViewNotification for PODetail.What happens at
if (args.Row > -1 )?
private static void edvPODetail_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
if (args.NotifyType == EpiTransaction.NotifyType.AddRow ||
args.NotifyType == EpiTransaction.NotifyType.Initialize ||
args.NotifyType == EpiTransaction.NotifyType.DeleteRow ||
args.NotifyType == EpiTransaction.NotifyType.InitLastView ||
args.NotifyType == EpiTransaction.NotifyType.InitAndResetTreeNodes)
if (args.Row > -1 )
decimal tvol=0;
for (int counter = 0; counter < (dgpo.Rows.Count); counter++)
tvol += Convert.ToDecimal(dgpo.Rows[counter].Cells[30].Value.ToString());
theadervolume.Text=tvol.ToString();
if (args.Row > -1 )
decimal tvol=0;
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Are you running any asyncronous BPM's or actual BPM's when you modify /
> update PO's? if that's the case there is where your problem is, your dataset
> is being modified outside of the client and the client is not being
> notified.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> *Quis custodiet ipsos custodes?*
> On Thu, Apr 7, 2011 at 2:16 PM, Anitha <anithayedavalli@...> wrote:
> > Exception caught in: Epicor.Mfg.BO.PO
> > Error Detail
> > Message: Row has been modified by another user and couldn't be updated.
> > Please press the Refresh button and re-enter your changes.
> > Type: UpdateConflict
> > Program: core/BizRuleEngine.p
> > Method: Main-Block
> > Table: PODetail
> > Row:
> > 0x003d0a5b00010000574845524520282850524f47524553535f5245434944203d20000000950008fffb0000000000000000000000000000000e29292000
> > Field: SysRevID
> > Stack Trace
> > at Epicor.Mfg.Proxy.POImpl.Update(PODataSet ds)
> > at Epicor.Mfg.UI.Adapters.POAdapter.Update()
> > at Epicor.Mfg.UI.App.POEntry.Transaction.Update()
> > Inner Exception
> > ERROR condition: The Server application has returned an error. (7243)
> > (7211)
> > Inner Stack Trace
> > at Progress.Open4GL.DynamicAPI.Session.runProcedure(String requestID,
> > String procedureName, ParameterSet parms, Boolean persistent, Boolean
> > internal_Renamed, Int64 procId, MetaSchema localSchema, Int32 stateModel)
> > at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
> > requestID, String fullProcedureName, ParameterSet inparams, Object procId,
> > at Progress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
> > requestID, String procedureName, ParameterSet parms, MetaSchema schema)
> > at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String
> > at
> > Epicor.Mfg.Core.CallContext.CallContextPersistentProc.runProcedure(String
> > procedureName, ParameterSet parameters, MetaSchema metaSchema)
> > at Epicor.Mfg.Core.CallContext.ProxyHelper.CallMethod(String methodName,
> > ParameterSet parameters, MetaSchema metaSchema, BLConnectionPool connPool,
> > Session connection, PersistentProc persistProc, CallContextDataSet
> > callContextDataSet)
