How to make a ComboBox accept only list values
Thank you all.
Based on replies from this forum and another user forum I put this together:
Open the form in Developer mode.
Go to Wizards
Form Event Wizard
Select Event Type – Load
Click Right Arrow to move Handler to right side.
Enter this in Code:  cboReasonCode.DropDownStyle =
Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
Click Update All Event Codes
Save and Exit
[Where cboReasonCode is the name of the combo box]
Anyone know how to force the combobox to accept only values from the list?  The combo box is working fine and I tried a retrievercombobox based on a UD Table with the same results.  It allows for items to be typed in freeform as well as selected from the list.  I need to prevent the freeform entries.  I only want items from the list or a blank value.  I believe I need to set DropDownStyle = DropDownList but I am not sure how to accomplish that.
Is there something similar to preprocessing in a BPM that can set this flag in a customization on the screen?  A load event or something?
For what it’s worth, I think this should be the default and you should have to change it if you want to allow freeform responses.
Thanks in advance,
Doug Oswald
Director of Information Technology
Fleetwood
www.fleetwoodfixtures.com
Extraordinary custom fixtures for the life of your brand!
Corporate Office
225 Peach Street Leesport Pennsylvania 19533
USA - Illinois • New York • Pennsylvania
P. 610 916 9999    F. 610 916 9900    C. 610 406 8200
International - China
Green Plus Certified • We Reclaim, Recycle and Respect the Environment
DropDownStyle is correct you have to do it on Load of the form in the script area.
Joshua Giese
Technology Solutions : CTO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Tuesday, January 26, 2016 9:56 AM
Subject: [Vantage] How to make a ComboBox accept only list values
Thanks in advance,
Doug Oswald
Fleetwood
Corporate Office
Joshua,
I have not done something like this before.  Can you provide a little more guidance?
Are talking about the Script Editor in the Customization?
Should it look something like this?
Private Sub PartForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles PartForm.Load
Dim DropDownList as Integer = 1
        Dim DropDown as Integer = 0
             ucbEpiCustom1.DropDownStyle = DropDownList
 End Sub
Something to that effect yes. You have the right _Load method. I’m not sure the exact syntax in VB but if you google it you will find what you are looking for. That DropDownList as Integer is not what you want. It’s an enumerated list that you will want to use instead.
Joshua Giese
Sent: Tuesday, January 26, 2016 11:01 AM
Subject: [Vantage] RE: How to make a ComboBox accept only list values
Joshua,
 End Sub
You can use the LimitToList property of the UltraCombo...
ucCombo.LimitToList = true;
This will prevent you from leaving the field if the value isn't  a valid value on the list.
Alternatively you can use the item not in list eventÂ
// ItemNotInList event
     private void ultraCombo1_ItemNotInList(object sender, Infragistics.Win.UltraWinEditors.ValidationErrorEventArgs e)
         e.RetainFocus = true;
         e.Beep = true;
     <span style="color:rgb(0,128,0);">// Display a message box indicating that the entered text is invalid.
MessageBox.Show( e.InvalidText + " is not a valid value.", "Invalid Entry" );
     <span style="color:rgb(0,128,0);">// Restore a previously valid value if one was entered, otherwise set a valid default value.
if ( e.LastValidValue != null )
this.ultraCombo1.Value = e.LastValidValue;
else
this.ultraCombo1.SelectedRow = this.ultraCombo1.Rows[0];
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
Quis custodiet
ipsos custodes?
On Tue, Jan 26, 2016 at 12:21 PM, Joshua Giese jgiese@… [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Â
Joshua Giese
Direct Phone:Â Â Â 920.593.8299
Office Phone:Â Â Â 920.437.6400 x342
Â
Â
Joshua,
Â
Â
Â
Â
 End Sub
Â
Â
</div>
<div style="color:#fff;min-height:0;"></div>
Interesting Jose, learn something new everyday.
Doug, here is how to set the DropDownStyle property if you're curious.
cbo.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
From: "Jose Gomez jose@... [vantage]" <vantage@yahoogroups.com>
To: Vantage <vantage@yahoogroups.com>
Sent: Tuesday, January 26, 2016 12:51 PM
Subject: Re: [Vantage] RE: How to make a ComboBox accept only list values
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394 --
#ygrps-yiv-1882424340yiv0729528394 .ygrps-yiv-1882424340yiv0729528394ygrp-photo-title{
clear:both;font-size:smaller;height:15px;overflow:hidden;text-align:center;width:75px;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394ygrp-photo{
background-position:center;background-repeat:no-repeat;background-color:white;border:1px solid black;height:62px;width:62px;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394photo-title
a,
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394photo-title a:active,
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394photo-title a:hover,
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394photo-title a:visited {
text-decoration:none;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394attach-table div.ygrps-yiv-1882424340yiv0729528394attach-row {
clear:both;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394attach-table div.ygrps-yiv-1882424340yiv0729528394attach-row div {
float:left;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 p {
clear:both;padding:15px 0 3px 0;overflow:hidden;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394ygrp-file {
width:30px;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394attach-table div.ygrps-yiv-1882424340yiv0729528394attach-row div div a {
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394attach-table div.ygrps-yiv-1882424340yiv0729528394attach-row div div span {
font-weight:normal;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 div.ygrps-yiv-1882424340yiv0729528394ygrp-file-title {
font-weight:bold;}
#ygrps-yiv-1882424340yiv0729528394ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp #ygrps-yiv-1882424340yiv0729528394hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp #ygrps-yiv-1882424340yiv0729528394ads {
margin-bottom:10px;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp .ygrps-yiv-1882424340yiv0729528394ad {
padding:0 0;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp .ygrps-yiv-1882424340yiv0729528394ad p {
margin:0;}
#ygrps-yiv-1882424340 #ygrps-yiv-1882424340yiv0729528394 #ygrps-yiv-1882424340yiv0729528394ygrp-mkp .ygrps-yiv-1882424340yiv0729528394ad a {
color:#0000ff;text-decoration:none;}
         e.Beep = true;
     <span id="ygrps-yiv-1882424340yui_3_16_0_1_1453822932084_20717" style="color:rgb(0,128,0);">// Display a message box indicating that the entered text is invalid.
     <span id="ygrps-yiv-1882424340yui_3_16_0_1_1453822932084_20733" style="color:rgb(0,128,0);">// Restore a previously valid value if one was entered, otherwise set a valid default value.
else
Jose C Gomez
Software Engineer
Quis custodiet
ipsos custodes?
On Tue, Jan 26, 2016 at 12:21 PM, Joshua Giese jgiese@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1882424340yui_3_16_0_1_1453822932084_20750">
  <div>
Joshua Giese
Joshua,
 End Sub
</div>
