I tried to print all parts including all revisions from the BOM Listing. I set Effective date to Dynamic(Today) and Parts to All selected. I also set the other columns to All. However, only the parts of the final revision were printed. On the other hand, if a specific Partrivision is selected from Partrivision, that Partrivision is output.
I need to print all Partivisions at once.
How can I output all the data? Please share your knowledge. Thank you.
If you do not inventory your material by a revision, then the report will display the latest approved revision. If the material holds two approved revisions on the same date, then the report will display the last revision in an alphabetical sequence.
