How to parameter Kanban
Hello everyone, I’m trying to train myself on Kanban (system rev 11.3 – Kinetic), but I’m stuck and can’t find the answers.
My need is to receive goods into a « Stock” warehouse with a bin associated to that warehouse, and then have a bin on the shop floor ( WH “Production”) with min-max settings for daily usage.
First question: In the Site-Detail section, should the Primary Warehouse be the “Stock”warehouse or the “Production” warehouse ? Do I need to set min-max parameters there?
In the Warehouse-Detail section, for the “production” warehouse , what action should I select? Stock - Manual Replenishment or Auto Replenishment? I also fill in the Supplier WH and Supplier Bin with the “Stock” Warehouse, but do I need to complete the Bin Detail section below?
For the warehouse detail of the “Stock” warehouse, how should I fill it in? And do I need to complete the Bin Detail section below?
Thank you very much
Here’s some notes from the past.
The logic is still the same.
The site page drives MRP results. The kanban settings do not drive MRP results.
Set Up KanBanFloorStock.docx (3.3 MB)
In addition - here’s the Kanban setup for purchasing too.
Purchasing kanban does not require AMM to execute the logic.
KanBan for Purchasing.docx (794.6 KB)
Thanks a lot for the documents. They are helpfull, but I think that I have some strange behavior… I can do all the steps until the page 7 with a manuel transfer order, but after that is not working. So I will continue my tests. There is something else that I do wrong…
Thanks !
