How to POST API to Bo.PartTrans
Please advise how to send rest api values ​​to Bo.Parttrans.
Which I tried and got the problem of not logging into the system.
Since this is PartTran, I think you’re definitely going to need to describe in detail what you are wanting to do and why.
:popcorn:
Because I have a program to produce products and then weigh them and want to receive them in this system.
After that, post the value with REST API to Epicor’s inventory as well.
Well I don’t think you are going to want to drop it directly into PartTran.
Lay out in detail what you want to do so we can advise you properly.
So, what must I do to send values ​​to my Epicor inventory through the API?
Production software has:(connected weighting scale)
Part, LOT, JobNum, QTY–>(weigh), warehouse, Bin
What screen is that? Report Qty?
On this screen, the user enters product data by Lot.
then after clicking the save (Ok button), need to post updated inventory via the API
The key is to find the transaction type you are trying to mimic.
Then find the BO to create the transaction type.
The BO will sort out any PartTran records.
I strongly recommend against dealing with the PartTran table, direct.
How do we integrate data via REST API into Epicor Inventory? Please suggest.
Like Andrew suggests, you would use the specified business object to get the work done.
Question back to you: how would you do these transactions at the standard Kinetic user interface? Which commands would you run?
I don’t mean to be rude, but if your question is one sentence for a task like this which very very complicated, the answer is to hire to knowledgeable consultant who can do the work for you.
