How to process a multplie nodes within nodeset (Service Connect)
Thanks for answer...
If there is no possibility to process multiple nodes without calling sub-workflow, what is the purpose of the 'Multiplicity' option where I can select 'multiple' or 'single'? This option is available during selection of input and output schema while configuring the 'conversion'.
Is it possible to use a Workflow recursively?. So the workflow will call itself?
Grzegorz
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> You'll need to pass that down another level to a sub workflow and
> process it then pass your results back to the workflow it came from.
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of tomojmail
> Sent: Thursday, February 25, 2010 7:37 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] How to process a multplie nodes within nodeset
> (Service Connect)
> When I am using a GetRows method in Service Connect, sometimes it gives
> me a one DataSet with multiple modes. For example MenuServices.GetRows
> can give me a result like following:
> GetRowsResponse
> Result
> MenuDataSet
> Menu
> Field1
> Field2
> Fieldn
> Menu
> Field1
> Field2
> Fieldn
> Menu
> Field1
> Field2
> Fieldn
> As you can see there are a multiple Menu nodes. How can I process each
> of them? Now Service Connect is processing only the first one.
When I am using a GetRows method in Service Connect, sometimes it gives me a one DataSet with multiple modes. For example MenuServices.GetRows can give me a result like following:
GetRowsResponse
Result
MenuDataSet
Menu
Field1
Field2
Fieldn
Menu
Field1
Field2
Fieldn
Menu
Field1
Field2
Fieldn
As you can see there are a multiple Menu nodes. How can I process each of them? Now Service Connect is processing only the first one.
Rob Bucek
FAX: (715)284-4084
Of tomojmail
(Service Connect)
GetRowsResponse
Result
MenuDataSet
Menu
Field1
Field2
Fieldn
Menu
Field1
Field2
Fieldn
Menu
Field1
Field2
Fieldn
