Thanks for replying.
When I do count(*) on the Empbasic and PREMPMAS tables, the count is
different. Why? I will try using the empbasic table instead of the
prempmas table in my dashboard.
Thanks again.
--- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@...>
Thanks again.
wrote:
>jcdept,
> Clinton,
> As long as you only need basic information (name, supervisor,
> address and phone, labor rate) you can use the EmpBasic table (fromEmployee
> Shop Employee setup) rather than PREmpMas (from the Payroll
> setup). We use average pay rates by job title for the labor ratesso
> this isn't the actual pay rate. The EmpBasic is synchronized withthe
> PREmpMas table by the business logic so you get the same data. Ifyou
> need the Payroll specific information such as SSNs or pay rates,you
> will need to use the PREmpMas table with hopefully a higher adminexempt
> level of security.
> The only piece of data that I have found to be a problem is the
> Payroll ClassID. I find it usefully for the time card reports to
> separate out the hourly employee which are done daily vs. the
> and non-exempt employees done weekly. So rather than allow accessto
> the PREmpMas, I have rigged an update query in Access to copy theObviously
> ClassID from the PREmpMas to ShortChar01 in the EmpBasic.
> not the best method, however being on 8.00, I don't have BPM to dothe
> updates. The user defined fields are not affected by any businessThis
> logic so I feel reasonably safe doing the updates through ODBC.
> keeps the firewall in place so only admin has access to PREmpMas.We
> don't add new people that often and they let me know quickly whenthey
> don't show on the time card reports so it seems to work wellenough. HTH
>wrote:
> Regards,
> Chris
> --- In vantage@yahoogroups.com, "mustardbuzzards" <c.edwards@>
> >that
> > Good Morning,
> > I have the payroll module active. Need the ability to write BAQ
> > show employee name.
> > How do you link the PREMPMAS table without giving up on security?
> > Is there way to populate/link/synchronize the empbasic table?
> > Thanks
> > Clinton
