How to Rename Application Studio Applications
Does anyone know if its possible to export an app rename it through the files downloaded and then reupload it with a new name?
Just rename the layer or the whole application?
The whole application
Do you have an example of what applications you want to rename?
Dashboards are possible with a little edit in the downloaded zip file but I’m not sure for non-dashboard apps.
Yea its a dashboard. Current naming convention on full display for your entertainment XD
You can use the old dashboard template trick. Export the application, edit the ZIP with 7-Zip to change the name and GUID, then import into App Studio.
Edit: Better yet use the new method with a copy app
Does this also work for layers made for the dashboard?
:man_shrugging: not sure sorry.
Copy Application does exactly this (not layers though)
I wasn’t sure if Gov Cloud can use the copy app… figured safest was to rec the old method.
It shouldn’t be a problem. There’s no special libraries required.
