How to run a customization on a form that pops up from the actio
I don't know that screen but when you go into customization and the subscreen has the same bo as the parent its working like that.
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Tue, 06 Sep 2011 16:30:44
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Re: How to run a customization on a form that pops up from the actions menu
Does this work the same for the Lot attribute screen on receipt entry? I made a customization on the lot form and it won't show up in receipt entry?
--- In vantage@yahoogroups.com, "Kevin Simon" <simstrak@...> wrote:
> Ephraim,
> That helped!!!
> Kevin
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> effgroups@...
> Sent: Wednesday, August 31, 2011 12:10 PM
> Subject: Re: [Vantage] How to run a customization on a form that pops up
> If I remember correctly you have to create a customization on the parent
> form with the same name and set it in the menu to run then the subform will
> also be called with the customization.
> HTH
> Ephraim Feldman
> From: "simstrak" <simstrak@... <mailto:simstrak%40yahoo.com> >
> Sender: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Date: Sat, 27 Aug 2011 00:05:56
> To: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
> Reply-To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> Subject: [Vantage] How to run a customization on a form that pops up from
> the actions menu
> I have an issue where, from Job Entry, I am clicking Actions -> Schedule ->
> Job Scheduling. I have a customization on the form that pops up here.
> However, when I am in developer mode, it doesn't pop up the typical screen
> that gives you the information to setup Process Calling and Sub Process
> Maintenance. I believe the job scheduling form is another form within the
> JobEntry dll.
> In these cases, how do you specify which customization to run on the called
> form?
> Thanks.
> Kevin Simon
I have an issue where, from Job Entry, I am clicking Actions -> Schedule -> Job Scheduling. I have a customization on the form that pops up here. However, when I am in developer mode, it doesn't pop up the typical screen that gives you the information to setup Process Calling and Sub Process Maintenance. I believe the job scheduling form is another form within the JobEntry dll.
In these cases, how do you specify which customization to run on the called form?
Thanks.
Kevin Simon
If I remember correctly you have to create a customization on the parent form with the same name and set it in the menu to run then the subform will also be called with the customization.
HTH
Ephraim Feldman
Subject: [Vantage] How to run a customization on a form that pops up from the actions menu
Thanks.
Kevin Simon
Ephraim,
That helped!!!
Kevin
effgroups@...
HTH
Ephraim Feldman
the actions menu
JobEntry dll.
form?
Thanks.
Kevin Simon
> Ephraim,
> That helped!!!
> Kevin
> effgroups@...
> HTH
> Ephraim Feldman
> the actions menu
> JobEntry dll.
> form?
> Thanks.
> Kevin Simon
