Hi,
I am getting the on hand qty for a part and lot number from each partbin the part might exist in. I would like to add those numbers up to get a total on hand qty for the lot. I think I need to do a foreach loop but I’m not sure what goes next.
var PartBinsTable = Db.PartBin.Where(x=>
x.Company == Session.CompanyID &&
x.PartNum == NewRecord.Character01 &&
x.LotNum == NewRecord.Character02).Select(x=>new{x.OnhandQty});
foreach(var PartBinRow in PartBinsTable)
From this part, you already have a list of all the OnHandQty values for your Part and Lot. (Each one is stored as an object with a single property … with a single-value result, you can just return the field you want: Select(x => x.OnHandQty) for a simpler result set.)
You can add a Sum to the end of your query to get a single decimal value (at least, I think OnHandQty is a decimal type).
It looks like this:
.Sum(obj => obj.OnHandQty);
Or if you change your Select to just pick the field itself, you can just sum the list of numbers:
.Sum();
Another option: The Sum function has the capability to Select the value to sum, so instead of Select then Sum, your whole query could look like this:
