How to update/add customer using web service proxy for Vantage 8.0
I am trying to build a mobile solution (i.e. web portal to access the
Vantage Service 8.0.3 via web service
adapter calls).
I am trying to update the customers by using the following
code:
System.IO.Stream streamInMemory = new System.IO.MemoryStream();
XmlSerializer s = new XmlSerializer(typeof
(Epicor.Mfg.BO.CustomerDataSet));
s.Serialize(streamInMemory, customerDataSet);
reader = XmlReader.Create(streamInMemory);
reader.MoveToContent(); //Move to the cd element node.
XmlDocument xDoc = new XmlDocument();
XmlNode xNode = xDoc.ReadNode(reader);
returnVal = customerAdapter.ExecuteMethod("Update", new object
[] { xNode });
where the customerDataSet is the new CustomerDataSet that I want
to update.
The code does NOT throw exception to me, but the returnVal[0] is
always null without any explaination. Of course, the customerDataSet
does not get updated.
Do any of you have had the similar experience? What is the correct
way to update a DataSet via Vantage webservice calls.
-- Charlie
