HyperLink in SSRS
I happen to be working in Report Builder, so I took a quick snip…
You can right-click on pretty much anything (Textbox, PlaceHolder, etc.) and open properties. Then, under “Action”, there is an option for “Go to URL”.
You can either put a stagnant value or an expression (which I would assume you’d use to insert a specific PONum to drive your target web address).
