Identity of Workstation
Hi Carl,
>Is there a way to get the current workstation ID?
Did you find any more about this?
I see CUR-WORKSTATIONID is listed in a tech tip but...
not working on either V8 or E9 that I tried.
However... I do see a WorkstationID in my traces:
- Epicor.Mfg.BO.ReportMonitor
- GetRowsKeepIdleTime
- Epicor.Mfg.BO.ReportMonitorDataSet
- <parameter name='whereClauseSysRptLst'
........ WorkStationID ='D2003 1'
- ]]></parameter>
I'm trying to unravel a printing issue, I don't think workstation has anything to do with my problem but now I'm pretty curious
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> P.S.
> I checked my user setup, workstation was blank.
> I selected a workstation and saved the user record.
> When I reopen the user record, the workstation field is blank.
> So... something missing in my setup?
> --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > I hadn't noticed this before.
> > I just checked and Workstation was (none) when I added it to my client view options.
> > V8.03.409C & E9.04.506.
> > I thought this used to work...
> > --- In vantage@yahoogroups.com, "CarlH" <carl.heeder@> wrote:
> > > CUR-WORKSTATIONID is a valid variable (the compiler doesn't complain) but there is no value there.
> > > I'm now suspecting that I have to do some sort of call to get it.
> > > > Did you try CUR-WORKSTATIONID already?
> > > > > In BPM's DCD-USERID returns the current user ID. Is there a way to get the current workstation ID?
P.S.
