Rick,
By very slowly, I mean 30-50 seconds for vantage to start up (compared to 10
seconds or less on faster PC's or terminal server). Up to 10 minutes for
purchasing suggestions to run to compared to 2 minutes or less on faster
PC's and Terminal server. I haven't timed the system going from screen to
screen, but on the faster pc's it is instantaneous, on those machines it
takes several seconds between each action, and transactions or reports that
require more data can take 15-20 seconds, which feels like forever when your
waiting.
Terminal Server is not the same thing as Citrix. Terminal server is
Microsoft's thin client solution. We use it alone, without Citrix. We use
terminal server for our remote sites to connect to our server and for our
clients here that need faster connections. The only limits are the number
of terminal server licenses and the power of the terminal server pc. The
terminal server pc has to have enough resources to perform well for all of
the client connections. Vantage should be the only software installed on
this PC. We have a P3, 733, 512 MB RAM, with 12 available client
connections, but typically only 2-4 simultaneous connections.
Sarah
waiting.
Sarah
