Import csv to engineering workbench
I’ve recently come across this thread that helped me import a csv to engineering workbench:
I want to know if there is a way to import more data than just partnum, qty, desc.
I personally add a lot of data in the purchasing and manufacturing comments tabs.
Is this possible?
Louis D.
EDIT WHOOPS…
I thought that referneced post was about using copy and paste inert/update.
— End edit —
  1. Personalize the Eng Workbench screen to show the two comment fields:
    Then they’ll show in the List view.
  2. Rearrange the columns to put the comments over near the fields you’re inserting/updating. And Save Layouts.
Now you should have those columns available to populate.
Calvin, even if you were mistaken this still helps a lot! I can copy paste that info in without having to click through the tabs to get there.
Directly importing would still be ideal for me, but this is a step in the right direction.
Thank you!
I thought of a real hack of a way to do it… I haven’t actually tested it.
It would be along the lines of adding the MfgComments to the PartDescription, with some unique identifier text. Then have a BPM extract that from the PartDesc, placing the comment into the appropriate table.
For example, if your PartDesc and Mfg Comment were:
  • PartDesc: SOLID GOLD WIDGET
  • Mfg Comment: TO BE BRONZE PLATED
the new PartDesc would be
SOLID GOLD WIDGET<mfgcom>TO BE BRONZE PLATED</mfgcom>
The BPM would break extract that into the two separate parts setting each in the BOMMtl.
I found that after I import the parts (as described in the link i posted) then I can copy that whole chart from the list tab.
I then pasted in excel and added the mfg and pur comments and pasted back into epicor.
Seems to work with a few extra steps. still better than changing one by one when I already have an excel doc with all the details.
