Receiving error when trying to import a library from Dev to Pilot. Receive Syntax Ok in dev and can promote to production.
Error shows function is SetResult.cs, which makes sense. Also shows (71,29), which I would think is line 71 position 29, but the function doesn’t have more than 30 lines. Is there a way to see the source code generated as a result of the function so I can see where it is struggling?
Error is: Cannot implicitly convert type ‘void’ to ‘string’, which I would think would generate an error in Dev if this was the case. It does reference a new UD table, but that has been migrated successfully, data model regened and shows green ‘in sync’.
