In MES while clocking in, everytime the shift pop up screen is appearing. The employees are having the permanent shift and no changes are happening to it They are requesting to hide the shift pop up screen. how to do that? kindly help.
Subha
You could do it with a customization on the shift select form. One way would be to perform a button click (with code) on the OK button once the form initializes, that way the employee will get clocked into their default shift.
Thanks Adam, its working in the developer mode. I am going to deploy in the production and update you. Got the note that I should use the same MES customization name for saving it.
