Indented BOM listing
I am working with Kinetic version 2025.1.11 and I am trying to pull the indented BOM data from the system to export to Excel. I have seen some older posts with code to allow this to happen, but I wasn’t sure if the older code would work with Kinetic. Does anyone have a BAQ or SQL code to allow me to pull this data? Ultimately, I am looking for the data as it shows in the Method Tracker/view costs area. Thank you.
The BAQ attached to this comment will work in Kinetic.
Thank you. I imported the query with no issues- will work with this.
