Hi Chris/Dawn,
Thanks for your help.
I made the change to the posting rules in our test database and that achieves exactly what we want.
Out of interest, I know Indirect Labor postings are on the Inv/Wip Rec Report in 607, will the unposted indirect transactions still be on the report after the posting rules change?
Regards,
Darryn
Regards,
Darryn
--- In vantage@yahoogroups.com, "Chris Robisch" <bluewine@...> wrote:
> We change the posting engine to not post Indirect Labor by copying the
> standard revision, changing the "If Transaction Value = 0" to "... >= 0 ...
> "End Rule". Then activiating the new revision. And we redo this on every
> upgrade.
> From: "Deirdre Sykes" <dsykes@...>
> To: <vantage@yahoogroups.com>
> Sent: Thursday, April 05, 2012 6:16 AM
> Subject: RE: [Vantage] Indirect Labor GL Controls (9.05.606A)
> > We just discovered the exact same thing. We found that you do not see it
> > on the inventory WIP/Reconciliation because the indirect labor does not
> > relate to a job or inventory related transactions. The only way to see at
> > least the hours is to run a Labor edit report. Running the labor edit
> > report, you can take the hours and then multiply by the labor dollars
> > assigned to that employee to get the cost that would be booking to the GL.
> > Hope this helps,
> > Deirdre Sykes | Staff Accountant
> > GSI Technologies, LLC | 311 Shore Drive | Burr Ridge, IL 60527
> > dsykes@...<mailto:dsykes@...> | Phone: 630.590.8130 |
> > Fax: 630.325.8197
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of darrynralph
> > Sent: Thursday, April 05, 2012 5:12 AM
> > Subject: [Vantage] Indirect Labor GL Controls (9.05.606A)
> > Hi,
> > When we were on Vantage 6.1 and 9.04 Indirect Labor wasn't an issue to us
> > as it didn't get posted anywhere. However since going to 9.05 Indirect
> > Labor now gets posted to the GL. We have set up the GL Controls on the
> > Indirect Labour Accounts but when we run a Capture COS/WIP nothing
> > happens. If we remove the GL Controls and run a Capture COS/WIP the
> > Indirect Labor does get posted but to our default Labor accounts.
> > Are we missing something? There is a tick box within the Indirect Labour
> > Accounts set up list view for 'Post Costs' but this also does nothing when
> > posting!
> > Any advice would be appreciated.
> > Thanks,
> > Darryn
> > CONFIDENTIALITY: The information contained in this email message,
> > including any attachment(s), may be privileged and confidential and
> > protected from disclosure. The email is not intended for transmission to,
> > or receipt by, any unauthorized persons. If the reader of this message is
> > not the intended recipient, or an employee or agent responsible for
> > delivering this message to the intended recipient, you are hereby notified
> > that any dissemination, distribution, or copying of this communication or
> > use of the information contained herein is strictly prohibited. If you
> > have received this electronic mail transmission in error, please delete it
> > from your system without copying or disseminating, and notify the sender
> > by Reply email, so that our address record can be corrected.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > No virus found in this message.
> > Checked by AVG - www.avg.com
> > Version: 2012.0.1913 / Virus Database: 2409/4914 - Release Date: 04/04/12
