Inner join causes duplicate rows
This is probably a simple SQL question, but I am at a loss. I have a stored procedure on an SSRS report for Scrap Details that returns 2 rows for each record. If I comment out the inner join below, then the results look correct. But, the JobMtl table is where we get the scrap cost, so I need it included. Can anyone tell me what’s wrong with this join, or what to add to it to make sure it does not return duplicate values? If need be I can post the whole sp, but this join is definitely the issue.
inner join
		(select
			JobMtl.Company,
			JobMtl.JobNum,
			JobMtl.AssemblySeq,
			JobMtl.RelatedOperation,
			JobMtl.TotalCost,
			JobMtl.QtyPer,
			JobMtl.IssuedQty,
			JobMtl.PartNum,
		CASE WHEN JobMtl.IssuedQty > 0 THEN (JobMtl.TotalCost / JobMtl.IssuedQty) * JobMtl.QtyPer ELSE 0 END as MtlUnitCost
		from erp.JobMtl
		where (JobMtl.Company = 'WSF') ) as Mtl on Mtl.Company = LaborDtl.Company
                            and Mtl.JobNum = LaborDtl.JobNum
                            and Mtl.AssemblySeq = LaborDtl.AssemblySeq
Is it duplicate rows or x rows for every jobmtl in the assembly and x happens to be 2?
I think you may need to add Mtl.RelatedOperation = LaborDtl.OperSeq to your join. I’m on mobile and am not sure if OperSeq is the correct name, but there should be something like that on LaborDtl if not.
Actually, it’s probably the latter. I note that although JobMtl.PartNum is the same for both rows, JobAsmbl.PartNum is different.
JobMtl.RelatedOperation and LaborDtl.OprSeq contain different values. Adding that to the join returned 0.
Hmm, might need to see more of your query to understand what you’re going for in terms of the relationship between LaborDtl and JobMtl.
select
	LaborDtl.Company,
	LaborDtl.ClockInDate,
	MONTH(LaborDtl.ClockInDate) as clockInMonth,
	YEAR(LaborDtl.ClockInDate) as clockInYear,
	EmpBasic.Name as ReportedBy,
	ResourceGroup.Description as ResGrpDesc,
	Resource.Description as ResDesc,
	LaborDtl.JobNum,
	LaborDtl.AssemblySeq,
	LaborDtl.OprSeq,
	JobAsmbl.PartNum,
	JobAsmbl.Description,
	LaborDtl.ScrapQty as Scrap_Res,
	LaborDtl.LaborQty,
	(LaborDtl.ScrapQty + LaborDtl.LaborQty) as TotalQty,
	Reason.Description as Reason,
	Mtl.MtlUnitCost,
	(Mtl.MtlUnitCost * LaborDtl.ScrapQty) as scrapCost_Mtl,
	(LaborDtl.LaborHrs) * (LaborDtl.LaborRate) AS LaborCost,
	(LaborDtl.BurdenHrs) * (LaborDtl.BurdenRate) AS BurdenCost,
	((LaborDtl.LaborHrs) * (LaborDtl.LaborRate))  + ((LaborDtl.BurdenHrs) * (LaborDtl.BurdenRate)) AS LbrBurCost,
	CASE
		WHEN (LaborDtl.ScrapQty + LaborDtl.LaborQty) = 0 THEN 0
		ELSE (((LaborDtl.LaborHrs) * (LaborDtl.LaborRate))  + ((LaborDtl.BurdenHrs) * (LaborDtl.BurdenRate))) / (LaborDtl.ScrapQty + LaborDtl.LaborQty) --Changed from Labor Qty only to Total Qty
	END AS LbrBurUnitCost,
	CASE
		ELSE ((((LaborDtl.LaborHrs) * (LaborDtl.LaborRate)) + ((LaborDtl.BurdenHrs) * (LaborDtl.BurdenRate))) / (LaborDtl.ScrapQty + LaborDtl.LaborQty)) * LaborDtl.ScrapQty
	END AS scrapCost_LbrBur, --Labor + Burden Unit Cost
	CASE
		WHEN(LaborDtl.ScrapQty + LaborDtl.LaborQty) = 0 THEN 0
		ELSE (((((LaborDtl.LaborHrs) * (LaborDtl.LaborRate)) + ((LaborDtl.BurdenHrs) * (LaborDtl.BurdenRate))) / (LaborDtl.ScrapQty + LaborDtl.LaborQty)) * LaborDtl.ScrapQty) + (Mtl.MtlUnitCost * LaborDtl.ScrapQty)
	END AS Total_ScrapCost
from erp.LaborDtl
inner join
		(select
			JobMtl.Company,
			JobMtl.JobNum,
			JobMtl.AssemblySeq,
			JobMtl.TotalCost,
			JobMtl.QtyPer,
			JobMtl.IssuedQty,
		from erp.JobMtl
																			--and Mtl.RelatedOperation = LaborDtl.OprSeq
left join Erp.Reason as Reason on
	LaborDtl.Company = Reason.Company
	and LaborDtl.ScrapReasonCode = Reason.ReasonCode
	and Reason.ReasonType = 'S'
inner join Erp.JobOper AS JobOper ON LaborDtl.Company = JobOper.Company
		and LaborDtl.JobNum = JobOper.JobNum
		and LaborDtl.AssemblySeq = JobOper.AssemblySeq
		and LaborDtl.OprSeq = JobOper.OprSeq
left join Erp.JobOper_UD ON JobOper.SysRowID = JobOper_UD.ForeignSysRowID
		and (JobOper_UD.Date01 IS NOT NULL)
inner join JobAsmbl AS JobAsmbl ON JobOper.Company = JobAsmbl.Company
		and JobOper.JobNum = JobAsmbl.JobNum
		and JobOper.AssemblySeq = JobAsmbl.AssemblySeq
inner join Erp.EmpBasic ON LaborDtl.Company = EmpBasic.Company
		and LaborDtl.EmployeeNum = EmpBasic.EmpID
inner join Erp.Resource AS Resource ON LaborDtl.Company = Resource.Company
		and LaborDtl.ResourceID = Resource.ResourceID
inner join Erp.ResourceGroup AS ResourceGroup ON Resource.Company = ResourceGroup.Company
		and Resource.ResourceGrpID = ResourceGroup.ResourceGrpID
where ScrapQty > 0
	and LaborDtl.ClockInDate >= '3/1/22'
	and (LaborDtl.Company = 'WSF')
order by LaborDtl.ClockInDate
In LaborDtl, you clock into an operation, the part you see is the job assembly part number.
When you are joining to JobMtl on Job / Asm, you are returning all the materials in that JobAsmbl / Assembly. You probably have 2 materials in the assemblies you are looking at.
Methods can assign related materials to operations, but it is not required, and when I look at my JobMtl table there is not a related operation sequence assigned.
You have 2 options I can see, either change your join to JobAsmbl ( assuming it has the fields you are looking for ), or join to a JobMtl that is grouped by Job / Assembly Seq, and has an aggregate function to roll up the field values you want.
