Happy new year to all of you Epi problem solvers out there.
Our end of year seemed to be going very smoothly, so smoothly in fact that I was dubious. Sure enough, not so smooth after all!
As it turns out, we are having an issue where our Received Not Invoiced (RNI) Report as of EOM for period 12 2023 no longer aligns with our RNI GL Account balance. According to accounting, something changed in the month of December which threw our RNI to GL completely off ($$$,$$$). End of Month for November-- apparently things were lining up fine.
We’ve gone down every road we could think of, and what we could find online (this forum, various posts), and have reviewed Epicor’s suggested KB articles. Nothing so far appears to explain the difference we are seeing between the RNI Report and the GL Account Balance.
Where I’m at is: I would like to produce a BAQ dataset that will show us all of the “In’s and Out’s” so to speak, of the December transactions that would have made up the RNI Report each day, with their respective timestamps / dates, and $ amts. This would be reviewed against the current transactions posted in the GL Account to determine if some transactions are “missing” from the GL, which is currently what we think might be happening since we expect the balance of the GL Account to be a larger (negative) number than it is.
I would appreciate any help or input from anyone on this issue, regardless of the BAQ I am trying to produce.
Regarding the BAQ, if anyone has a similar BAQ export they would be willing to share that would be awesome! What I’m thinking is I should be able to use either the PartTran table, or the RcvDtl table to create a sort of historical listing of transactions/events that either would have RAISED the RNI balance during December, or LOWERED the balance.
My understanding so far of the RNI is that it’s essentially just RcvDtl (and dropship) data that is marked Received, and where Invoiced = False. This, in theory, would be enough to go on to produce a table of data showing the “in” (receipt that wasn’t invoiced), and then the “out” (the date/time the receipt was invoiced).
However, what about cases where receipts might have been un-received, or even deleted? I’ve read a bit on other posts where users saw RNI issues or variance in the GL caused by this, but how can you determine (Data-wise) that this is the case? My thought is that there would still be traceable Part Transactions in those cases (is this correct?), so that is where I am going to start by determining the transaction types and other flags that I need to look for.
Thanks so much for reading.
