We had something similar on version 8. I think it was a date issue...Try to do a BAQ on the Part Tran table for the part and display both system date and tran date - see if you have any very odd dates...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Len Hartka
Sent: Wednesday, May 29, 2013 2:43 PM
Subject: [Vantage] "Inspection Processing" causes PartBin records with Blank WHSE and Bin. Can see them in PTHT screen.
Good Day:
Has anyone seen:
Records are INS-STK transaction.
This then causes the beginning balance of Transaction (PTHT)
screen to be Negative.
Started with 9.05.700C. First level of helpline is not
seeing any calls on it.
Sun is on E9 Verion: 9.05.700C - SQL- Unidata -
Enterprise-since 4/15/2012
Len
Len.hartka@...<mailto:Len.hartka%40sunautomation.com>
Leonard C. Hartka
66 Loveton Circle, Sparks, MD, 21152
Work: 410-329-3560 ext 120
FAX: -329-3564
Work Cell: 443-255-7192
Personal Cell: 410-292-8744
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Good Day:
Has anyone seen:
Len
Leonard C. Hartka
FAX: -329-3564
