It seems to me that using a blank template to âreprintâ a tag takes away all accountability from the entire process and makes the Inspection Processing a moot pointâŠ
Is there no way to go back and make a change to that Inspection record to correct the quantity entered?
Iâm not sure I get the issue here. I mean, you can f*** around with the Epicor process too.
Enter whatever quantity you want
Print tag.
Change qty in the inspection.
Save that qty. Now youâve got a tag and a transaction that donât match. Maybe one of the two numbers gels with reality.
Only way to actually guarantee the label matches the transaction is to disable the canned label and trigger an auto-print via BPM. Even thenâŠyou can always take a 2nd swing at inspections by creating a Nonconformance.
@jtownsend - Perhaps there is no issue and my lack of experience with the Enhanced Quality Module in Epicor is in itself the issue. This falls into that old saying of âI donât know what I donât knowâ, ya know?
