Installation error - A local file header is corrupt
During installation 10.2.700, I get the following message. A local file header is corrupt. Epicor does install but this message continues to pop up when trying to open Epicor. Any ideas?
On a client install?
Yes
Have you deleted the root Epicor folder (C:\Epicor normally) and tried a new install?
Yes, this is not specific to one machine. The install has been done on multiple machines with the same results.
Have you tried redeploying the app in the EAC? Then trying a new client install.
I have not tried that. Existing installs run fine.
