Sarah
Try this. Go into the profile dir (on a win95 machine it is
c:\windows\profiles\username\ICA client) and edit the Appsrv.ini file.
Then under the published application name group, change the entry
'Address = pub app name' to the actual IP address of your server...
here is mine for example...
[Vantage IBM]
TransportDriver=TCP/IP
DesiredHRES=4294967295
DesiredVRES=4294967295
ScreenPercent=0
Description=Vantage IBM
Address=Vantage IBM <<<<<******** change this to the IP address of
your server********
InitialProgram=#Vantage IBM
IconPath=C:\PROGRAM FILES\CITRIX\ICA CLIENT\PN.EXE
IconIndex=1
ConnectType=1
MaximumCompression=Off
Compress=On
PersistentCacheEnabled=Off
MouseTimer=0
KeyboardTimer=0
AudioBandwidthLimit=1
UseDefaultSound=On
DefaultSoundType=1
UseDefaultEncryption=On
EncryptionLevel=1
UseDefaultWinColor=On
UseDefaultWinSize=Off
DesiredWinType=8
TWIMode=On
SavePNPassword=On
ICASOCKSProtocolVersion=-1
ICASOCKSProxyPortNumber=1080
I have had your problem before and this seemed to help. It has
something to do with the ICA browser not responding.
Another thing to try is to write a batch file called 'restartica.bat' on
the Citrix server as follows
net stop icabrowser
net start icabrowser
<eof>
The batch file seemed to work temporarily, but replacing the IP address
seemed to be permanent.
Britt Moelling
M&M Manufacturing .
Sarah Vareschi wrote:
Britt Moelling
M&M Manufacturing Co., Inc.
[Vantage IBM]
ScreenPercent=0
your server********
IconIndex=1
ConnectType=1
Compress=On
MouseTimer=0
KeyboardTimer=0
UseDefaultSound=On
DefaultSoundType=1
EncryptionLevel=1
DesiredWinType=8
TWIMode=On
SavePNPassword=On
net stop icabrowser
<eof>
Britt Moelling
M&M Manufacturing .
> Hi Tim,[Click Here!]
> Thanks for the response. Ok, here's my set-up. We have our citrix
> server running only windows NT 4.0 terminal server edition, citrix
> metaframe 1.8 for terminal server 4.0 and Vantage.
> The clients connecting are all NT. All local clients connected
> fine. On the remote side, we are connecting over a T1 line, TCP/IP
> protocol. We can continue to connect thru terminal server without
> issue.
> Each PC has one machine ID, ex. 'MLEITEC' and the same user id to log
> into terminal citrix and/or citrix 'mleitec'. We have one user per
> PC.
> On each client, after running the install I first went into the
> properties for the custom connections and changed the network
> protocol to TCP/IP, I left the 'server group' set to the default of
> primary, and I added our citrix server IP address of '172.16.19.87'
> to the address list. I then double-clicked 'add ICA Connection' and
> chose 'WAN' as the connection type. Ont the second screen, when I
> try to use the drop-down list to pick my application, I receive the
> message that the 'ICA browser failed to return any names'. If I
> change to 'server' and type in the server name or IP address
> everything works and it connects to the citrix server desktop.
> Only one computer has successfully connected to the vantage published
> application. However, after rebooting the machine, that connection
> directly to the published application failed to work as well. I then
> connected directly to the IP address, whch worked, and then the
> connection to the Published application came back. There has to be
> something easier, right?
> Thanks so much for replying,
> Sarah
> --- In vantage@egroups.com, "Tim Care" <ecfmis@e...> wrote:
> > Sarah,
> > Once I got the machines setup, they have been pretty stable.
> > Were you logged in on this machine with a different user ID?
> > I've found that the settings are set by user. What I've had to
> > do is get one user configured correctly, go into their profile
> > directory and copy all of the ini files back to the location where
> > I installed the citrix program files. This way, the server
> information
> > is installed when each user starts the Citrix program.
> > What Operating system are you using on the Client?
> > What version of Citrix?
> > What software is used on the Server?
> > What version of the Citrix Client are you using?
> > Hopefully, I can help.
> > Tim Care
> > Electro Chemical Finishing
> eGroups Sponsor
> We no longer allow attachments to files. To access/share Report
> Files, please go to the following link:
> http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it,
> go to www.egroups.com, login and be sure to save your password, choose
> My Groups, choose Vantage, then choose Files. If you save the
> password, the link above will work the next time you try it.)
Britt Moelling
